speedingcheetah 39 Posted September 14, 2015 Posted September 14, 2015 (edited) This app would be great...but....Everything I play through the app sounds horribly compressed. /Like 96k mp3. Is there no settings to adjust the audio stream quality in the official app? I found another app called "Smart Player Media Browser" That does the same thing as the official Emby app, but it pops up Transcode settings every time u load a video....annoying...but it at least allows me to adjust the audio quality. Also....it very often does not release tuners when I try to play live tv from my HDR Prime. Edited September 14, 2015 by speedingcheetah
Deathsquirrel 745 Posted September 14, 2015 Posted September 14, 2015 What is the source file audio format and what OS are you running the app on?
speedingcheetah 39 Posted September 15, 2015 Author Posted September 15, 2015 (edited) What is the source file audio format and what OS are you running the app on? A recording of Live TV made by Emby Server from my HD Home Run Prime. mpeg-2 .ts file. Ac3 audio. Also...Live TV sounds quite degraded as well. Only sounds this bad in this app. All other programs to stream video and tv sound fine. Win 8.1 Edited September 15, 2015 by speedingcheetah
