softworkz 5133 Posted September 13, 2015 Posted September 13, 2015 Hi, I've been searching through all of the forum, but I haven't found some definite information as to which options for ISO playback are working with Emby for WMC? I'm currently using Virtual CloneDrive instead of Daemon tools. Is there any way to make this work with "Emby for WMC"? Or is an Installation of "Daemon Tools" the only way to handle ISO files? Regardless of the answer, I would find it really helpful to have a clear indication/selection on the configuration dialog as to which ISO mounting tools can be used with "Emby for WMC"... (and maybe, in which cases "Use Autoplay" should be checked or not). Thanks and best regards, softworkz
Solution porkbone 48 Posted September 13, 2015 Solution Posted September 13, 2015 I use Virtual Clonedrive with out issues. Open the Emby for WMC Configurator and select the Extenders & ISO's tab. Change the selected player from Daemon to Virtual Clonedrive by browsing to the Elaborate Bytes folder and select VCDMount.exe. I have Autoplay checked. I also have VCD checked for Eject Unmounts Image File. Hope that helps! 2
softworkz 5133 Posted September 13, 2015 Author Posted September 13, 2015 (edited) Porkbone, great, it worked once i chose "VCDMount.exe". Previously I tried daemon.exe, but it didn't work. Just a minor suggestion for improvement I had would be to list all compatible ISO mounting tools and the corresponding command line parameters from within the configuration dialog.. Best regards, softworkz Edited September 13, 2015 by softworkz 1
softworkz 5133 Posted September 29, 2015 Author Posted September 29, 2015 Just for completeness: I made some modification to the configurator to clearly indicate the supported tools and this has been picked up by the project. In the future the dialog will look like this: 1
