1971camaroguy 32 Posted September 12, 2015 Posted September 12, 2015 Having some trouble getting emby to see and display some pictures I have mixed inside a folder with some videos. Not sure if I am doing something wrong or if this is even possible. I created an unset (mixed) library in emby with several folders. Each of these folders contain two mp4 videos, folder.jpg, and a folder containing five .jpg pictures I need to use for slides. Emby will display the folder icon in it's web interface, I can play the videos, but when I click on the slide folder there's nothing there. Just wondering if I am doing something wrong or if this is even possible?? If not I may have to skip my roku idea of doing this Any help would be great, I need to try and figure something out pretty quick Thanks again
Luke 42185 Posted September 12, 2015 Posted September 12, 2015 You should set that up as a photo library
1971camaroguy 32 Posted September 12, 2015 Author Posted September 12, 2015 You should set that up as a photo library Thanks for the quick reply, even with videos in the folder too?, or should I separate it out? Just trying to make the easiest route that works.
ebr 16307 Posted September 12, 2015 Posted September 12, 2015 Just plain videos (like ones taken with your phone) will work fine inside of a photo library.
1971camaroguy 32 Posted September 12, 2015 Author Posted September 12, 2015 (edited) Cool thanks, they are just 3 minute video clips.Still messing with it, I'm playing with this on my sever at home and I have a huge library to scan and it's taking a bit. Maybe they aren't showing up yet. Edited September 12, 2015 by 1971camaroguy
1971camaroguy 32 Posted September 12, 2015 Author Posted September 12, 2015 I changed the folder on the server I'm actually gonna have these on to photo's instead of unset and it looks like it's going to work. Thanks again everyone
