hjone72 9 Posted September 12, 2015 Posted September 12, 2015 Hi, Is there a way to restrict which users can sync to which devices? It now seems that all users are able to sync to my phone, however I want them to only sync to either their device or their folder. Thanks,
bluemonkey07 590 Posted September 12, 2015 Posted September 12, 2015 (edited) you can restrict users to certain devices within the users/access in the dashboard Edited September 12, 2015 by Vidman
hjone72 9 Posted September 12, 2015 Author Posted September 12, 2015 (edited) On further inspection this does not achieve the desired result. If I "untick" a device for a user, that user can no longer login from that device. I simply want to prevent users from Syncing items to devices that they are not logged in to. For example: User 1: Is logged into their phone. They should be able to sync to their phone. They should also be able to sync to a folder. User 2: Is not logged into any device. They should not be able to sync to User 1's phone (Currently they can). They should be able to sync to a folder. Thanks, EDIT: Furthermore, Is it possible to disable syncing to devices completely? I really only want to use folder sync. Edited September 12, 2015 by hjone72
Luke 42185 Posted September 13, 2015 Posted September 13, 2015 Unfortunately we don't have that level of granularity in the settings at this time so the best thing to do is just ignore the extra sync targets in the drop down list
bluemonkey07 590 Posted September 13, 2015 Posted September 13, 2015 (edited) On further inspection this does not achieve the desired result. If I "untick" a device for a user, that user can no longer login from that device. I simply want to prevent users from Syncing items to devices that they are not logged in to. For example: User 1: Is logged into their phone. They should be able to sync to their phone. They should also be able to sync to a folder. User 2: Is not logged into any device. They should not be able to sync to User 1's phone (Currently they can). They should be able to sync to a folder. Thanks, EDIT: Furthermore, Is it possible to disable syncing to devices completely? I really only want to use folder sync. Your original request was to not allow other users to sync to your device... So you would disable access to your phone for those users... But now it seems your are requesting something different In your example you would disable user 2s access to user 1s phone But you still want to allow user 2 to be able to login via user 1s phone? Edited September 13, 2015 by Vidman
Luke 42185 Posted September 13, 2015 Posted September 13, 2015 Well it disabled more than he wanted so it looks like the settings just aren't granular enough for what he's asking
hjone72 9 Posted September 13, 2015 Author Posted September 13, 2015 Your original request was to not allow other users to sync to your device... So you would disable access to your phone for those users... But now it seems your are requesting something different In your example you would disable user 2s access to user 1s phone But you still want to allow user 2 to be able to login via user 1s phone? You are correct, you could just disable access to other devices for each user. The issue with this is; If someone tries to login to a new devices, by default the device will be disabled until approved. Thanks for the replies, but as Luke has stated, at this stage it seems that the functionality I am looking for does not exist.
bluemonkey07 590 Posted September 13, 2015 Posted September 13, 2015 You are correct, you could just disable access to other devices for each user. The issue with this is; If someone tries to login to a new devices, by default the device will be disabled until approved. I don't know if this statement is correct Luke? I believe new devices are enabled for all users by default until specifically disabled
