Teddy 100 Posted September 11, 2015 Posted September 11, 2015 (edited) Using last 2.12 version the channels (trailers) are missing. I remember in some previous versions was available. Have I a local server issue or is something normal for this version? Edited September 11, 2015 by Teddy
Luke 42241 Posted September 11, 2015 Posted September 11, 2015 is the channel available in the web interface?
Teddy 100 Posted September 11, 2015 Author Posted September 11, 2015 Yes Luke, and in Emby for WMB or android application. Only is missing in Roku
Luke 42241 Posted September 11, 2015 Posted September 11, 2015 Ok, try the zip installation of the channel. should be fixed there. http://emby.media/community/index.php?/topic/8001-emby-for-roku-channel/ Or it will be fixed in the next update to the app. 1
Teddy 100 Posted September 11, 2015 Author Posted September 11, 2015 Thanks to help Luke. I'll await for next release.
Solution Luke 42241 Posted September 11, 2015 Solution Posted September 11, 2015 I've also posted the update to the beta channel as well. 1
Teddy 100 Posted September 12, 2015 Author Posted September 12, 2015 Fastastic Luke, with the Beta installed the channels are now available. Thanks again for your incredible support.
