scope99 7 Posted September 10, 2015 Posted September 10, 2015 Hi I was checking out the new update which seems great, however when I set the view to poster card for a movie folder the spinning circle came on and the app did not display the content. Subsequent attempts to change the view to any other view fail. The error was replicated on three other movie folders with the same result. A reinstall resolved the problem. Also does anyone know why the posters are now different sizes? Some new ones are shorter than older ones. This isn't a app issue however as I have noticed it in the web app as well.
Solution Luke 42242 Posted September 10, 2015 Solution Posted September 10, 2015 http://emby.media/community/index.php?/topic/25265-v2413-apk-problems/ 1
