mediacowboy 438 Posted April 13, 2016 Posted April 13, 2016 (edited) Luke, Where is the Emby TV Guide data stored? My provider just updated the lineup and schedules diret reflects this on the website but emby is still showing the old data. Update: Maybe this isnt a issue with emby.. Here is what leads me to beleave this. 1.Deleted schedules direct information from tv plugging2. Disabled tuner.3. Reenabled tuner4. Verified the channels. Everything looks great.5. Added back my schedules direct information and channels are wrong again. @@rkulagow, Is this maybe an issue with the server's and not everything be updated yet? Edited April 13, 2016 by mediacowboy
rkulagow 19 Posted April 23, 2016 Posted April 23, 2016 I'd need to know some more specifics. The easiest way to do that is to open a ticket at the Schedules Direct website.
mmac 0 Posted February 4, 2017 Posted February 4, 2017 I'd need to know some more specifics. The easiest way to do that is to open a ticket at the Schedules Direct website. I'm actually using an XML epg link from my provider. Works fine obviously through the browser - tried several of their links. Was working just fine but since I tried the beta it messed things up and I haven't been able to get it back to being functional.
maegibbons 1287 Posted February 4, 2017 Posted February 4, 2017 @mrmac What is your tuner type? Provide a sample of your xmltv guide data and m3u file if you are using m3u. Krs Mark
mmac 0 Posted February 4, 2017 Posted February 4, 2017 @mrmac What is your tuner type? Provide a sample of your xmltv guide data and m3u file if you are using m3u. Krs Mark It's an M3U tuner type running on Windows - this is what the XML looks like The M3U works fine (ie. the channels will open so I don't think that's the issue) guide.xml
maegibbons 1287 Posted February 4, 2017 Posted February 4, 2017 (edited) Have you manually mapped the channels using the three dot menu item of the xmltv tv guide setup? Krs Mark Edited February 4, 2017 by maegibbons
