jj12345 25 Posted September 8, 2015 Posted September 8, 2015 I see my guide in WMC. I see channels in Emby web client with a tag under the channel saying what is playing now. I see "What's On" and "Upcoming Programs", etc. in Emby web client (so there must be some guide data available I would guess) I see that when I run the refresh guide task in Emby that ServerWMC served up 12,000+ "EPG Entires". I have guide data when using the Windows client. But the guide in the web client is completely empty. Emby Version = 3.0.5724.3 (latest) ServerWMC Version = 1.0.0.58 build 1199 (latest) Any thoughts?
krustyreturns 191 Posted September 8, 2015 Posted September 8, 2015 First thought is: I did not spell 'entries' incorrectly - but you did make check. Did your channels transfer over? What do you see when you click the channels tab (next to the guide tab) in your web client? Also make sure the date and time are set correctly in your client machine.
Solution jj12345 25 Posted September 8, 2015 Author Solution Posted September 8, 2015 Date and time are fine and as noted channels are showing up. I closed the browser session and reloaded and now the guide is showing up. Guess it just needed a kick in the pants.
