[Titan BETA 3.5.2] Battery is low?
Hiya,
Just a question; when using the Titan Beta 3.5.2 skin, the home menu shows a low battery (0%) icon in the lower right corner. Does this mean anything?
Also, I am using only menu shortcuts on the home screen. Is there a way to navigate to the bottom part (where the power button is) when the tile actually has a sub-menu (such as movies, recently added etc)?
Thanks for all the great work!
  • 2 weeks later...
Just in case someone was wondering too: it looks like this is functionality for tablets and alike. For some reason it shows by default when installing the skin, it can be switched off in the skin settings though.
Guest
