maisto99 0 Posted September 7, 2015 Posted September 7, 2015 My setup is Windows 8.1 x64 with 16MB RAM, and 120GB OS Drive, and 4TB Data Drive. I recently uninstalled Emby (used remove all option) and now I can't get it to reinstall. After running "setup" it downloads than loads Emby and will create a shortcut but it doesn't work. I get the error message "The item 'MediaBrowser.ServerApplication.exe' that this shortcut refers to has been changed or moved, so this shortcut will no longer work properly." I've uninstalled Emby, and ran CCleaner but it won't reinstall. Any assistance will be greatly appreciate!
Solution BarryAmerika 24 Posted September 7, 2015 Solution Posted September 7, 2015 My guess would be an antivirus type program has quarantined the .exe Are you running Nortons internet security or anything like that? Check quarantined items and if you see it there look for an option to allow or trust this file. 2
