ABotelho 3 Posted September 7, 2015 Posted September 7, 2015 Running Emby 3.0.5713.6, on CentOS 7. Images do not appear at all for my movies and TV shows. I've attached my log, right after attempting to force a refresh of the images in the MetaData Manager. Any ideas? emby-server.log
Luke 42243 Posted September 7, 2015 Posted September 7, 2015 that's not much of a log file. are you sure that's all of it? 1
ABotelho 3 Posted September 8, 2015 Author Posted September 8, 2015 Are logs not present in /var/log ?
Solution fc7 123 Posted September 8, 2015 Solution Posted September 8, 2015 They are under /var/lib/emby-server/logs Sent from my iPad using Tapatalk 1
ABotelho 3 Posted September 10, 2015 Author Posted September 10, 2015 (edited) Alright, sounds good. I basically did a clean install of CentOS 7. Tried installing docker, but I can't even get Docker's service running So I'll give pure CentOS 7 a try one more time... If the same things happen again, I'll pull the logs from the appropriate location. Edited September 10, 2015 by ABotelho
ABotelho 3 Posted September 10, 2015 Author Posted September 10, 2015 After reinstalling Emby, the images now appear to be coming in! Odd that they wouldn't originally come through, seeing as I took the same process. Maybe a CentOS package was updated since, I honestly have no idea.Thank you once again for the patience guys, I honestly appreciate it immensely!
