USB TV Tuner
SO, can I use a USB TV Tuner? I thought I could.
I have a DS212j. The tuner works in Video Station.
You have to access the tuner via tv headend or one of the other tv server software then add the appropriate plugin to mediabrowser
Thanks for the reply.
I was wanting everything to be running on the synology nas. What options might I have for this?
You could use tvheadend. It is avaiable throught the https://synocommunity.com/
I used it a long time on my raspberry.. should work fine on synology too.
Tell us your experiences!
EDIT:
Sorry, just found that actuall release of tvheadend ist available on: http://syno.dierkse.nl/
Edited by 1ch_h4lt
Dvblink also works on synology with usb tuners
