CBers 7554 Posted November 28, 2013 Posted November 28, 2013 Originally posted by @@Starkadius here. Run Media Browser Classic Configurator (located "C:\Program Files (x86)\MediaBrowser\MediaBrowser\Configurator.exe") After installation has completed, click the 'ThemeVideo Backdrops' plugin and then 'Configure' In Backdrop sources select 'Theme backdrops' Launch MediaBrowser Classic and go to settings Click on 'Config' Finally for the theme you are using (in this case Chocolate) go to 'Chocolate General' and make sure 'Show video Backdrop' is checked. Then click continue and restart MBC for changes to take effect. 1
ebr 16331 Posted November 28, 2013 Posted November 28, 2013 FYI - The MBC configuration part of these instructions is specific to the Chocolate theme. Any theme that shows the currently playing item as a full backdrop should also work. If your theme has an option to show its own video backdrops, you may need to disable it with this plug-in installed. 1
