Angelblue05 4132 Posted September 20, 2015 Posted September 20, 2015 (edited) Also, tell us the title of what you tried to play. Do you need credentials to access the network share you've set (unraid\mnt)?Sent from my iPhone using Tapatalk Edited September 20, 2015 by Angelblue05
skank 85 Posted September 20, 2015 Author Posted September 20, 2015 Trying to play "300" Log: http://xbmclogs.com/pjai0uaur No credentials needed Did everyhing u guys told me
skank 85 Posted September 20, 2015 Author Posted September 20, 2015 I dont see it in there either, i tried 300 and it says ninjago?
Angelblue05 4132 Posted September 20, 2015 Posted September 20, 2015 (edited) External players should work correctly with our add-on. It's been asked previously and others have successfully been able to get it to work. So I'm convinced it can be fixed, but something is not right in your set up... we just need to figure out what. It's still not able to access your paths... ERROR: InputStream: Error opening, smb://Unraid/mnt/Tvshows/Ninjago Masters Of Spinjitsu/Ninjago Masters Of Spinjitzu 20150312-2.mkv I think what's missing from your path might be the computer name/internal ip address. My paths are: smb://corruption-pc/tvshows where corruption-pc is the name of the computer where the media is located. It can also be substituted by the ip address. So make sure you have that be part of your path substitution in emby. If you are unsure, you can also try to add a new media folder in Emby dashboard > library. Add folder via Network entry and see what the final path looks like. That's what your path substitution should look like as well. Edited September 20, 2015 by Angelblue05
skank 85 Posted September 20, 2015 Author Posted September 20, 2015 it has nothing to do with my external player... latest log was on my normal windows kodi, without external player it happens too i tried like you said with add folder via network but that i cant fill in? its immediately my folders or mount if i chose network, and then i want to go further its again the same root folders strange why is it saying ninjago anyway if i try 300 ?
Angelblue05 4132 Posted September 20, 2015 Posted September 20, 2015 I know it has nothing to do with the external player. I was just saying that it should work. Something else in your set up is not right - and I believe it to be your paths. Try adding the internal ip address to your path substitution then. So they look like: \\192.168.0.xxx\Unraid\mnt\ I don't know why it would say a different title than it was. Anyway, the problem is Kodi can't file the file at the location you have so the path must be incorrect.
skank 85 Posted September 20, 2015 Author Posted September 20, 2015 something is broken, im sure, it worked before and i didnt change anything at my media side, only client side
skank 85 Posted September 20, 2015 Author Posted September 20, 2015 normally its \\192.168.0.117|movies\... OR \\Unraid\movies\... you want me to try both ip|unraid|... ?
Angelblue05 4132 Posted September 20, 2015 Posted September 20, 2015 Ok well try with ip\movies then. Then reset your kodi library so your local paths update.
skank 85 Posted September 20, 2015 Author Posted September 20, 2015 Problem is the same but why was it looking for lego ninjago mkv while i pressed 300?
skank 85 Posted September 20, 2015 Author Posted September 20, 2015 Ok well try with ip\movies then. Then reset your kodi library so your local paths update. still the same after resync
Angelblue05 4132 Posted September 20, 2015 Posted September 20, 2015 Ok... if you put your path substitution in windows explorer, is it able to find your content??
skank 85 Posted September 20, 2015 Author Posted September 20, 2015 tried again playing walking dead S1E1 http://xbmclogs.com/p0pjxqkzc i lookd into log it says it cant find it, although that is the correct addres
skank 85 Posted September 20, 2015 Author Posted September 20, 2015 Ok... if you put your path substitution in windows explorer, is it able to find your content?? No
Angelblue05 4132 Posted September 20, 2015 Posted September 20, 2015 So your paths are still incorrect. You've put \\192.168.0.117\mnt\Tvshows and it won't load so how can Kodi access them. You need to find whatever network share makes your content accessible so Kodi can also have access to them...
skank 85 Posted September 20, 2015 Author Posted September 20, 2015 I found it ! Got damn too easy i tried this ecvery time /mnt/movies to \\unraid\mnt\movies but it is without mnt lol off course so it had to be /mnt/movies to \\unraid\movies lol too easy 1
Angelblue05 4132 Posted September 20, 2015 Posted September 20, 2015 Good job! And now everything works in Kodi after you've reset resync your library once more?
skank 85 Posted September 20, 2015 Author Posted September 20, 2015 Man looked for it all weekend lol
skank 85 Posted September 20, 2015 Author Posted September 20, 2015 Good job! And now everything works in Kodi after you've reset resync your library once more? yeah good god lol 1
skank 85 Posted September 20, 2015 Author Posted September 20, 2015 Yeah thanks all for having patience lol
