julianb 39 Posted November 28, 2013 Posted November 28, 2013 Hi, have any sorted out how to use an external player like TMT6 to play folderBD/iso ? So far MPC-HC is working just fine, but TMT6 just starts, but no movie is loaded. I've tried the {PATH} but it does not work, TMT6 just starts but does not load up any movie.. Is there any solution for this? Thanks
Solution vj950 5 Posted November 29, 2013 Solution Posted November 29, 2013 Enter following: {PATH} /Play I use the WMC plugin (uMCEPlayer6.exe) for TMT 6. The player loads instantly, is a seamless playback, and once you stop, you come back to MBT. You can use WMC plugin without running WMC, just make sure you change your preferences (such as audio output options, BD live options etc) once you load the uMCEPlayer6, as it does not carry the preferences from standalone player. This command works for standalone app as well. It works for TMT5 (both WMC and standalone). 1
Nelcruz 3 Posted November 30, 2013 Posted November 30, 2013 Make sure you select mount for the iso option In external player setup. I had probs with bd folders but isos work perfectly. I only have {PATH}
julianb 39 Posted December 1, 2013 Author Posted December 1, 2013 Thank you both! btw, I could only get TMT6 MCE to work, not the standalone :S
