Zero_Kool 5 Posted November 28, 2013 Posted November 28, 2013 My current media is not displaying the folder metadata correctly? Attached is a pic> How can I get it to view all the same? It used to work fine before...not sure if a update caused a change?
ebr 16332 Posted November 28, 2013 Posted November 28, 2013 I don't understand what the problem is...
Tikuf 663 Posted November 28, 2013 Posted November 28, 2013 Think he is referring to the folder in among the ep shots. Changing the collapse number I think it is? Its been so long since i even looked at that bit.
ebr 16332 Posted November 28, 2013 Posted November 28, 2013 Ah, okay. If a TV item has more than one new episode, they are rolled up into the series and season on that view. You can change that behaviour by modifying the RecentItemCollapseThreshold in the config file.
Zero_Kool 5 Posted November 28, 2013 Author Posted November 28, 2013 Thanks for the replies, can you path me to that file location and what variable or value needs to be altered?
ebr 16332 Posted November 29, 2013 Posted November 29, 2013 %appdata%\mediabrowser-classic\configuration There will be multiple files in there - one for each user profile. I gave you the tag in the message above. But, be sure that's what you really want. The system is designed to group multiple episodes nicely into series and seasons which makes it much easier to see more information in the recent list.
