fc7 123 Posted September 2, 2015 Posted September 2, 2015 I was wondering if Emby server has any mechanism for metadata and images prunning/cleanup. For example when an item is removed or refreshed in the library is there any process that will check if old or not needed anymore metadata and images related to that object should be purged? The idea would be to keep the server and its data as light and clean as possible. Thanks Sent from my iPad using Tapatalk
Solution Luke 42243 Posted September 3, 2015 Solution Posted September 3, 2015 yes, the cache folders clean up after themselves 1
fc7 123 Posted September 3, 2015 Author Posted September 3, 2015 Excellent. Thanks Luke Sent from my iPad using Tapatalk
