Rew452 15 Posted September 1, 2015 Posted September 1, 2015 I still am having problems getting Live TV to work on my systems here is the log; can someone see what is wrong? I have 3 SD HDHR Primes which work fine in WMC and SD apps. IT seems to lock the tuner that is used and the only way to clear is to reboot the tuner used. Everything works fine for movies, no transcoding at all. Thanks 2015-09-01 18:29:31.5368 Info - App: HttpClientManager GET: http://192.168.1.135:2869/upnphost/udhisapi.dll?content=uuid:ffa43cc0-380d-43e3-8ae5-893e92122edf 2015-09-01 18:29:31.5368 Info - App: HttpClientManager GET: http://192.168.1.135:2869/upnphost/udhisapi.dll?content=uuid:ffa43cc0-380d-43e3-8ae5-893e92122edf2015-09-01 18:32:46.5692 Info - App: Udp message sent to 192.168.1.69:409442015-09-01 18:32:46.5692 Info - App: Udp message sent to 192.168.1.69:409442015-09-01 18:32:47.7860 Info - App: Udp message sent to 192.168.1.69:367272015-09-01 18:32:47.7860 Info - App: Udp message sent to 192.168.1.69:367272015-09-01 18:32:47.8328 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/ping2015-09-01 18:32:51.2960 Error - DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5713.6 Command line: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Administrator does not have an image of type Primary MediaBrowser.Common.Extensions.ResourceNotFoundException at MediaBrowser.Api.Images.ImageService.GetImage(ImageRequest request, IHasImages item, Boolean isHeadRequest) at MediaBrowser.Api.Images.ImageService.Get(GetUserImage request) at lambda_method(Closure , Object , Object ) at ServiceStack.Host.ServiceRunner`1.Execute(IRequest request, Object instance, TRequest requestDto) 2015-09-01 18:32:51.2960 Error - DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5713.6 Command line: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe HTPC does not have an image of type Primary MediaBrowser.Common.Extensions.ResourceNotFoundException at MediaBrowser.Api.Images.ImageService.GetImage(ImageRequest request, IHasImages item, Boolean isHeadRequest) at MediaBrowser.Api.Images.ImageService.Get(GetUserImage request) at lambda_method(Closure , Object , Object ) at ServiceStack.Host.ServiceRunner`1.Execute(IRequest request, Object instance, TRequest requestDto) 2015-09-01 18:32:51.2960 Error - HttpServer: Error processing request for /mediabrowser/Users/7023fa26879c6170eee01731f7304255/Images/Primary?MaxHeight=370&EnableImageEnhancers=true *** Error Report *** Version: 3.0.5713.6 Command line: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe HTPC does not have an image of type Primary ServiceStack.HttpError No Stack Trace Available 2015-09-01 18:32:51.2960 Error - HttpServer: Error processing request for /mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Images/Primary?MaxHeight=370&EnableImageEnhancers=true *** Error Report *** Version: 3.0.5713.6 Command line: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Administrator does not have an image of type Primary ServiceStack.HttpError No Stack Trace Available 2015-09-01 18:32:51.2960 Error - NotFoundHttpHandler: 192.168.1.139:8096 Request not found: /mediabrowser/Users/7023fa26879c6170eee01731f7304255/Images/Primary?MaxHeight=370&EnableImageEnhancers=true2015-09-01 18:32:51.2960 Error - NotFoundHttpHandler: 192.168.1.139:8096 Request not found: /mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Images/Primary?MaxHeight=370&EnableImageEnhancers=true2015-09-01 18:32:52.7312 Info - UserManager: Authentication request for Administrator has succeeded.2015-09-01 18:32:52.9496 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/validate2015-09-01 18:34:20.3882 Info - App: HttpClientManager GET: http://192.168.1.242/lineup.json2015-09-01 18:34:20.6378 Info - App: HttpClientManager GET: http://192.168.1.148/lineup.json2015-09-01 18:34:20.8718 Info - App: HttpClientManager GET: http://192.168.1.110/lineup.json2015-09-01 18:34:21.1214 Info - App: HttpClientManager GET: http://192.168.1.242/2015-09-01 18:34:21.1370 Info - App: HttpClientManager GET: http://192.168.1.242/tuners.html2015-09-01 18:34:21.4802 Info - App: HttpClientManager GET: http://192.168.1.242/tuners.html2015-09-01 18:34:21.5114 Info - App: HttpClientManager GET: http://192.168.1.242/tuners.html2015-09-01 18:34:21.5894 Info - App: HttpClientManager GET: http://192.168.1.242/tuners.html2015-09-01 18:34:22.6346 Info - App: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150717\ffmpeg.exe -fflags +genpts -i "http://192.168.1.242:5004/auto/v134" -map_metadata -1 -threads 0 -sn -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 29680000 -bufsize 59360000 -vsync vfr -profile:v high -level 51 -force_key_frames "expr:gte(t,n_forced*3)" -vf "yadif=0:-1:0,scale=min(iw\,2176):trunc(ow/dar/2)*2" -sc_threshold 0 -codec:a:0 aac -strict experimental -ac 6 -ab 320000 -af "adelay=1,aresample=async=1" -hls_time 3 -start_number 0 -hls_list_size 0 -hls_base_url "hls/bdd7732aab00cd8570bec8745c02e607/" -y "C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\transcoding-temp\bdd7732aab00cd8570bec8745c02e607.m3u8" 2015-09-01 18:34:29.5767 Info - App: HttpClientManager GET: http://192.168.1.242/tuners.html2015-09-01 18:34:37.5795 Info - App: HttpClientManager GET: http://192.168.1.242/tuners.html2015-09-01 18:34:46.5808 Info - App: HttpClientManager GET: http://192.168.1.242/tuners.html2015-09-01 18:34:56.5804 Info - App: HttpClientManager GET: http://192.168.1.242/tuners.html2015-09-01 18:34:58.6240 Info - App: Killing ffmpeg process for C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\transcoding-temp\bdd7732aab00cd8570bec8745c02e607.m3u82015-09-01 18:34:58.6396 Error - DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5713.6 Command line: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe A task was canceled. System.Threading.Tasks.TaskCanceledException No Stack Trace Available 2015-09-01 18:34:58.6396 Error - HttpServer: Error processing request for /mediabrowser/videos/cb4498256dffa9dad45eae48fcfa90c5/live.m3u8?DeviceId=ae8f322deced9bf1&MediaSourceId=74600bd4278c4f769bd19873486bc5a6native&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=-1&VideoBitrate=29680000&AudioBitrate=320000&MaxAudioChannels=6&MaxWidth=2176&Level=51&ClientTime=1441146859594&MaxVideoBitDepth=8&Profile=high&PlaySessionId=7189832c46024f3b9d3ac93101113bee&api_key=314179c992114f209133a46a4667554b *** Error Report *** Version: 3.0.5713.6 Command line: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe A task was canceled. ServiceStack.HttpError No Stack Trace Available 2015-09-01 18:34:59.6381 Info - App: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150717\ffmpeg.exe -fflags +genpts -i "http://192.168.1.242:5004/auto/v134" -map_metadata -1 -threads 0 -sn -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 29680000 -bufsize 59360000 -vsync vfr -profile:v high -level 51 -force_key_frames "expr:gte(t,n_forced*3)" -vf "yadif=0:-1:0,scale=min(iw\,2176):trunc(ow/dar/2)*2" -sc_threshold 0 -codec:a:0 aac -strict experimental -ac 6 -ab 320000 -af "adelay=1,aresample=async=1" -hls_time 3 -start_number 0 -hls_list_size 0 -hls_base_url "hls/bdd7732aab00cd8570bec8745c02e607/" -y "C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\transcoding-temp\bdd7732aab00cd8570bec8745c02e607.m3u8" 2015-09-01 18:35:03.6317 Info - App: Deleting partial stream file(s) C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\transcoding-temp\bdd7732aab00cd8570bec8745c02e607.m3u82015-09-01 18:37:04.6417 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3Packages.json2015-09-01 18:37:04.6885 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3Packages.json
ebr 16334 Posted September 2, 2015 Posted September 2, 2015 You didn't say what app you are using and the log isn't in debug mode so I can't see it but my best guess is that the server is not able to keep up on the transcode - or there could be another issue. That log just says the transcode was shut down. More information about exactly what you are doing and with what app and the transcode log would probably shed some light.
Rew452 15 Posted September 4, 2015 Author Posted September 4, 2015 Sorry ebr I did not get a notice that you replied. The server should be more than capable, I5 @3500mhz, 8gB ram running WHS 2011, 1gB wired network. Will turn on debug mode and repeat today using LiveTV and post logs. Why it is using Transcoder, I don't know as all my Movies play to my other pc clients full tilt - no transcoding necessary. Clients I am using are Emby WMC and Theater also Chrome. The first time I install LiveTV as a add-on was the day it was released as part of the server and something went wrong as far as I can tell. Thanks
Rew452 15 Posted September 4, 2015 Author Posted September 4, 2015 (edited) OK, this time it work a little choppy using Chrome. Emby Log.txt device.TXT Configurator-16112014e1896eafad644cb994c63313825680e2.log Thanks Edited September 4, 2015 by Rew452
