Problem getting commentary audio track to work.
Hello,
I am currently putting one of my tv series on my computer so that I can view them through Emby when I came across a problem with an episode that has a Commentary audio track. Viewing the file (.m4v) that Emby looks at through VLC, I can select either audio track and listen to the commentary or just the normal episode. In Emby though it doesn't work.
Using Chrome (updated) I select the episode (after manually refreshing-just in case) and I can select the musical note for these two options:
eng - aac - LC - 160kbps - 2 ch (D)
When I select either one, I get a short reload of the video and the audio resumes, but no commentary. It's always the normal audio. There doesn't seem to be a way to see which audio track is currently being used (that'd be a nice addition!) so perhaps it's failing to load the other one and then just defaults to the main one?
Why would it work on the actual file with VLC but not work in Emby? Any help would be very appreciated.
