chevy7 0 Posted September 1, 2015 Posted September 1, 2015 Hello, I just started using the Live TV function of Emby yesterday and today I noticed that a number of my channels do not have any guide data. I checked the server log and found this: 2015-09-01 09:48:55.7228 Info - App: Channel Station ID is: 32466 2015-09-01 09:48:55.7228 Info - App: HttpClientManager POST: https://json.schedulesdirect.org/20141201/schedules 2015-09-01 09:48:59.2390 Info - App: HttpClientManager POST: https://json.schedulesdirect.org/20141201/programs 2015-09-01 09:49:00.4114 Info - App: HttpClientManager GET: http://169.254.5.114:49152/0/description.xml 2015-09-01 09:49:00.4114 Info - App: HttpClientManager GET: http://169.254.5.114:49152/0/description.xml 2015-09-01 09:49:17.3699 Info - App: HttpClientManager POST: https://json.schedulesdirect.org/20141201/metadata/programs 2015-09-01 09:49:18.8916 Info - App: Finished with EPGData 2015-09-01 09:49:19.0478 Info - App: Channel Station ID is: 52670 2015-09-01 09:49:19.0478 Info - App: HttpClientManager POST: https://json.schedulesdirect.org/20141201/schedules 2015-09-01 09:49:21.7248 Info - App: HttpClientManager POST: https://json.schedulesdirect.org/20141201/programs 2015-09-01 09:49:41.7505 Error - App: Error getting response from https://json.schedulesdirect.org/20141201/programs *** Error Report *** Version: 3.0.5713.6 Command line: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe -service Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe The operation has timed out System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) 2015-09-01 09:49:41.7505 Error - App: Error getting programs for channel KETVDT2 (KETV-DT2) *** Error Report *** Version: 3.0.5713.6 Command line: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe -service Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe The operation has timed out MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1e.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsync>d__7.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Server.Implementations.LiveTv.Listings.SchedulesDirect.<GetProgramsAsync>d__18.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetProgramsAsync>d__3d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Server.Implementations.LiveTv.LiveTvManager.<RefreshChannelsInternal>d__c6.MoveNext() InnerException: System.Net.WebException The operation has timed out at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) So you can see that it pulls down the data for one channel and then it times out on the next channel. Since this is just part of the log a few channels down it works just fine for a channel or two but then times out again on other channels. Any ideas? Thanks.
ebr 16334 Posted September 1, 2015 Posted September 1, 2015 Most likely an issue either on the SD end or somewhere between you and them.
mellomade 141 Posted September 1, 2015 Posted September 1, 2015 I am seeing the same thing - their site looks to be timing out.
