marcelovz 3 Posted September 1, 2015 Posted September 1, 2015 (edited) Hi I downloaded and install Emby Beta 3.0.5713.6 on my Windows 8.1 Pro x64 and i'm having the folowing issues: 1) When using Emby for android 2.4.8 (latest) when try to stream video to my device, the video keeps loading forever and don't play and I had to restart my phone and in my PC the ffmpeg.exe keeps runing using high memory rate until I restart Emby Srver. 2) So I downgrade to Emby 3.0.5675.1 and the video stream are ok, but when I try to play musics, the Emby for Android play wrong musics, i.e., I choose one music and Emby for Android play another music, and if I choose other music, Emby for Android start to paly the previous wrong music. The only combination that works fine is Emby 3.0.5675.1 and Emby for Android 2.3.98. Less bad that I had saved earlier versions of Emby for Android, otherwise I could no longer use Emby on my Android.I hope that before making this official version of Emby Beta, you really test the Emby Server with Emby for Android, because once published the official version can not go back Thanks for your attention. Edited September 1, 2015 by marcelovz
Luke 42201 Posted September 1, 2015 Posted September 1, 2015 Can you supply more info? http://emby.media/community/index.php?/topic/790-how-to-report-a-problem/ Thanks.
marcelovz 3 Posted September 1, 2015 Author Posted September 1, 2015 Can you supply more info? http://emby.media/community/index.php?/topic/790-how-to-report-a-problem/ Thanks. Sure, but to do this, I have to install again the Beta Version, and now I´m using the Stable version. I'm afraid to have problems if I reinstall the Beta version. How can I help you without have problems ? Thnaks
Luke 42201 Posted September 1, 2015 Posted September 1, 2015 I'll work with you. We'd like to get the stable server release out, so better to go back to the beta and report whatever your issue is.
marcelovz 3 Posted September 1, 2015 Author Posted September 1, 2015 I'll work with you. We'd like to get the stable server release out, so better to go back to the beta and report whatever your issue is. Ok. So let's go. in about 15 minutes I wil begin to post the logs 1
marcelovz 3 Posted September 1, 2015 Author Posted September 1, 2015 (edited) I'll work with you. We'd like to get the stable server release out, so better to go back to the beta and report whatever your issue is. Hi Attached are the logs (Emby_logs.zip) and the procedures (Emby_Procedures.txt) that I made with time and description. Please let me know if you received. Please read the Emby_Procedures.txt. It's important. Thanks Emby_Procedures.txt Emby_Logs.zip Edited September 1, 2015 by marcelovz
Luke 42201 Posted September 1, 2015 Posted September 1, 2015 well for now, we just want to get the new server released, so can you try again with the release version of the android app + beta server? thanks.
marcelovz 3 Posted September 1, 2015 Author Posted September 1, 2015 well for now, we just want to get the new server released, so can you try again with the release version of the android app + beta server? thanks. But these logs was already maden with the Emby Beta and the Android (2.4.8 _latest) thanks
marcelovz 3 Posted September 1, 2015 Author Posted September 1, 2015 But these logs was already maden with the Emby Beta and the Android (2.4.8 _latest) thanks But these logs was already maden with the Emby Beta and the Android (2.4.8 _latest) Did you see the logs ? thanks
marcelovz 3 Posted September 1, 2015 Author Posted September 1, 2015 well for now, we just want to get the new server released, so can you try again with the release version of the android app + beta server? thanks. I dont understand whats happening. i´m using the Beta server.... Why in the log appear 3.0.5675.1 ? There is different path for the logs of the Beta version ?
marcelovz 3 Posted September 1, 2015 Author Posted September 1, 2015 (edited) I dont understand whats happening. i´m using the Beta server.... Why in the log appear 3.0.5675.1 ? There is different path for the logs of the Beta version ? If I was in the Stable version the errors would not have happened In the zip file there two servers logs the correct is server-63576665053.txt refer to the Beta Server Edited September 1, 2015 by marcelovz
marcelovz 3 Posted September 3, 2015 Author Posted September 3, 2015 Hi Luke I saw a new alpha release 3.0.5724 and I would like to know if the problems that I reported in this post were fixed, because I'm afraid to update and continue with the same problems. If I upgrade to the new version, is there any way to downgrade to version 3.0.5675.1?Thank you very much for your attention.
marcelovz 3 Posted September 5, 2015 Author Posted September 5, 2015 (edited) No answer yet ? I'm waiting for a reply please. I need to know if I update my Emby Server, I can do a Downgrade to the earliy version. I'm waiting Thanks Edited September 5, 2015 by marcelovz
marcelovz 3 Posted September 5, 2015 Author Posted September 5, 2015 well for now, we just want to get the new server released, so can you try again with the release version of the android app + beta server? thanks. Hi Luke I saw a new alpha release 3.0.5724 and I would like to know if the problems that I reported in this post were fixed, because I'm afraid to update and continue with the same problems. If I upgrade to the new version, is there any way to downgrade to version 3.0.5675.1? Thank you very much for your attention.
ebr 16309 Posted September 5, 2015 Posted September 5, 2015 The current release is not alpha - it is a full Release level server. The only way we'll be sure if the issue is fixed is if you try it and tell us.
marcelovz 3 Posted September 5, 2015 Author Posted September 5, 2015 The current release is not alpha - it is a full Release level server. The only way we'll be sure if the issue is fixed is if you try it and tell us. Thanks for your attention If I update, there is any way to downgrade to early version ? Thanks
ebr 16309 Posted September 5, 2015 Posted September 5, 2015 When the server updates, it creates a backup of the old version called "System.old". If you upgrade and it doesn't work, you can shut down the server and then copy this folder back to "System".
marcelovz 3 Posted September 6, 2015 Author Posted September 6, 2015 (edited) When the server updates, it creates a backup of the old version called "System.old". If you upgrade and it doesn't work, you can shut down the server and then copy this folder back to "System". Hi Thanks for your attention I updated my Emby Server (today) to the full Release level server, but unfortunately are happening exactly the same problems as described in this post. EXACTLY THE SAME I had to downgrade the Emby Server for the stable version 3.05.675.1 and the Emby for Android to version 2.3.80, so that everything works as it should. I hope that these problems are solved because as did a monthly subscription to have the sync feature and more and I paid for Emby for Android too. Is there any estimate of when these problems will be solved? Because I like to have my Emby Server updated. Thanks Marcelo Edited September 6, 2015 by marcelovz
Luke 42201 Posted September 6, 2015 Posted September 6, 2015 I'm still not sure there is a problem to be honest, so at the moment I'm currently not doing anything for it. The logs don't show any evidence of a problem. I think it's possible you could see the same problem on both servers if you try enough times.
marcelovz 3 Posted September 6, 2015 Author Posted September 6, 2015 I'm still not sure there is a problem to be honest, so at the moment I'm currently not doing anything for it. The logs don't show any evidence of a problem. I think it's possible you could see the same problem on both servers if you try enough times. Hi Luke No. it's only happen with the new server. I tried several times with the new server and the old. In the old server all works fine every time, even trying to play same movie many times. Thanks
marcelovz 3 Posted September 6, 2015 Author Posted September 6, 2015 I'm still not sure there is a problem to be honest, so at the moment I'm currently not doing anything for it. The logs don't show any evidence of a problem. I think it's possible you could see the same problem on both servers if you try enough times. I'm still not sure there is a problem to be honest, so at the moment I'm currently not doing anything for it. The logs don't show any evidence of a problem. I think it's possible you could see the same problem on both servers if you try enough times. There is any way to generate logs in Emby for Android ?
marcelovz 3 Posted September 6, 2015 Author Posted September 6, 2015 Hi Luke No. it's only happen with the new server. I tried several times with the new server and the old. In the old server all works fine every time, even trying to play same movie many times. There is any way to generate logs in Emby for Android ? Thanks
marcelovz 3 Posted September 11, 2015 Author Posted September 11, 2015 Hi I downloaded the latest version of Emby for Android (2.4.15) and now the problems with the movies that I had with the Emby Server 3.0.5724.3 was solved. But I found new problems: 1) The srt subtitles don't work. If I change my subtitle to srt, noyhing happens and the subtitle is not shown. Only embed subtitles (vosub) are working. 2) When playing any music, the pause button does not work in the footer bar, or going for the remote (controls). Only the stop button works in remote (controls). Thanks
Luke 42201 Posted June 17, 2017 Posted June 17, 2017 Hi I downloaded the latest version of Emby for Android (2.4.15) and now the problems with the movies that I had with the Emby Server 3.0.5724.3 was solved. But I found new problems: 1) The srt subtitles don't work. If I change my subtitle to srt, noyhing happens and the subtitle is not shown. Only embed subtitles (vosub) are working. 2) When playing any music, the pause button does not work in the footer bar, or going for the remote (controls). Only the stop button works in remote (controls). Thanks @@marcelovz these should all be resolved now, thanks.
