gillmacca 17 Posted November 28, 2013 Posted November 28, 2013 Here is my setup. Laptop 1, (server software installed), will only be used by Andrew in MBT Laptop 2 will only be used by Ryan in MBT HTPC will be used by both Andrew and Ryan in MBT Is it possible to do the following: Hide Ryan on Laptop 1 Hide Andrew on Laptop 2 But still have both available on the HTPC Thanks for your help
Luke 42288 Posted November 28, 2013 Posted November 28, 2013 For now you can hide both and use the manual login screen, then later once MBT has auto-login features you can utilize that. We don't currently have hide per device options though.
