knottz 9 Posted August 30, 2015 Posted August 30, 2015 (edited) I just thought i'd try out the BETA build and noticed that the layout of the website has changed. Noticed mainly when your about to play some content but I have come across an annoying bug, would like some insight into why this happens? (I have provided a screenshot)As you can see the title overlaps the image, which i'm assuming it shouldn't, sometimes it loads fine and more times then not it doesn't.I also noticed if I right click inspect element using chrome, this will fix the issue until the next page refresh etc.(EDIT: I don't think the inspect element is the reason it re-aligns itself, It seems that once the browser window size is adjust it sorts itself out but until then it wont, i've tried editing the css a little but having no luck) Edited August 30, 2015 by knottz
Luke 42185 Posted August 30, 2015 Posted August 30, 2015 Did you try searching to find similar reported issues?
knottz 9 Posted August 30, 2015 Author Posted August 30, 2015 (edited) No I haven't, I do apologise. But the reason being i'm not sure what my search term would be to find related reports?EDIT: just tried a few search terms, not having any luck. I'd appreciate it if you know where to look? Edited August 30, 2015 by knottz
Happy2Play 9800 Posted August 30, 2015 Posted August 30, 2015 Here's one http://emby.media/community/index.php?/topic/24594-format-of-web-client-not-correct-until-refresh/
knottz 9 Posted August 30, 2015 Author Posted August 30, 2015 Ahh thank you. No fix as of yet it seems.
Happy2Play 9800 Posted August 30, 2015 Posted August 30, 2015 Seems to be mixed reviews for each browser and server version.
