wsramahi 7 Posted August 30, 2015 Posted August 30, 2015 I recently made a fresh emby server setup and changed my fire still configuration to point to the new server, but i found out that fireTV connects at first to the old setup and then connects to the new setup, yet keeping the first connection active untill i turn it of completely. Both connections shows same AFTM with the same IP but deferent credentials. Maybe the first configuration's are still there and active?
ebr 16335 Posted August 30, 2015 Posted August 30, 2015 Try "Clear Data" for the app. This will cause you to have to re-set any options you had but those should be minimal.
