dibsta 0 Posted August 30, 2015 Posted August 30, 2015 Hi All Been using chromecast and iphone setup then decided to try Firestick so got app from amazon app store (only a trial) so purchased in app unlock £3.33 yesterday 29/08/15 today it says it needs to be unlocked again. im connected to amazon Can someone help Dave
ebr 16335 Posted August 30, 2015 Posted August 30, 2015 Sounds like some sort of issue confirming the purchase with Amazon. Try re-starting the device.
dibsta 0 Posted August 30, 2015 Author Posted August 30, 2015 Hi ebr Ive restarted my device several times still no joy im login into my Amazon account and all prime stuff is workig Dave
ebr 16335 Posted August 30, 2015 Posted August 30, 2015 I'm not sure what else to tell you to try but, if you attempt the purchase again, it should realize you've already purchased it (as long as it truly was purchased on the same account).
dibsta 0 Posted August 30, 2015 Author Posted August 30, 2015 (edited) Hi ebr Did what you suggested repurchased it said i all ready own it now working Thanks Dave Edited August 30, 2015 by dibsta
