mjktg99 35 Posted September 1, 2015 Posted September 1, 2015 Don't hold me to this but I think if that lineup url works then it is DLNA capable... I'm thinking that since Windows 10 sees it as a digital media server then it is getting recognized for its DLNA capabilities. If that's the case, that's cool because I thought I missed the boat on the newer devices. I have had my prime for a while...
mjktg99 35 Posted September 1, 2015 Posted September 1, 2015 Silicondust confirmed that my device works with DLNA I'm including some additional screenshots. The Server is seeing the tuner AND recognizing that I am watching TV on another app (InstaTV Pro) so there's a step or setting somewhere that I must have missed and I'm not sure what it is. Also, in the server is the tuner enabled?
theGeek 4 Posted September 1, 2015 Author Posted September 1, 2015 Win10 sees the HDHR on the network Yes the tuner is enabled I only have the HDHR and you only have to run the channel scan twice. I'm going to try another back end - this is very disappointing. I'm going to chalk it up to still being in beta and I hope the final version fixes whatever problem I'm experiencing.
theGeek 4 Posted September 1, 2015 Author Posted September 1, 2015 well - it works. I decided, for the fun of it, to delete the tuner and re-add it. Now it working. No idea what changed but hey, at least it works
theGeek 4 Posted September 1, 2015 Author Posted September 1, 2015 Used the same IP - I had to add it manually both times so I'm not really sure. Sent from my iPhone using Tapatalk
theGeek 4 Posted September 1, 2015 Author Posted September 1, 2015 I am still having problems with getting the guide to work - I'm signed up with Schedules Direct and confirmed my login information. Not sure what the problem there is.
rkulagow 19 Posted September 1, 2015 Posted September 1, 2015 @theGreek Please send me your Schedules Direct username so that I can check the server side.
theGeek 4 Posted September 2, 2015 Author Posted September 2, 2015 Sent - thanks for looking into it Sent from my iPhone using Tapatalk
ebr 16334 Posted September 2, 2015 Posted September 2, 2015 SD is having some issues at the moment but they are working on it.
