JohnnyM 40 Posted November 27, 2013 Posted November 27, 2013 I noticed today that movies sort by name that have a numeric title are sorted differently in the Web Client than they are sort in MBC. The web client appears to sort strictly based on alpha orders with numeric sorting before alpha characters but the Classic client sorts the numeric first but based on the numeric value. You can see an example in the attached image. All of the sort titles are correct and the theme does appear to have any impact on the sort. I tried ROC and Diamond Is there a setting that I have missed in either of the clients?? I would like for the sort to be consistent.
ebr 16354 Posted November 28, 2013 Posted November 28, 2013 MBC has specific logic to handle this situation. The server may not.
foghat 65 Posted December 6, 2013 Posted December 6, 2013 I as just going to start a post about this. Is this considered a bug in the server sort logic? On the Server and in MBT, I am seeing 'The 40 Year Old Virgin' sorting before '9'. That just ain't right.
swhitmore 781 Posted December 6, 2013 Posted December 6, 2013 I as just going to start a post about this. Is this considered a bug in the server sort logic? On the Server and in MBT, I am seeing 'The 40 Year Old Virgin' sorting before '9'. That just ain't right. It looks at the first character (negating 'The'). 4 < 9
Luke 42288 Posted December 6, 2013 Posted December 6, 2013 check your sort name in metadata, however i'll adjust sort name comparer so that it uses a natural sort algorithm
foghat 65 Posted December 6, 2013 Posted December 6, 2013 It looks at the first character (negating 'The'). 4 < 9 Yes that is exactly what it is doing. Which isn't quite right - as the number is 40 not 4 check your sort name in metadata, however i'll adjust sort name comparer so that it uses a natural sort algorithm Sort name is correct: 40 Year Old Virgin, The 9 Thanks for looking into.
