Green_Trousers 0 Posted August 29, 2015 Posted August 29, 2015 Good evening all, hopefully I have a simple problem using Tags in place of Parental Controls. Simply put, I can’t guarantee the ratings are correct or indeed in the correct format. So I thought Tags might be the answer. I have cleaned the library to simplify matters and now have 2 movies. One with "XXXXX" in the tags metadata the other without. When I log in with the kids account I can see neither movie. Their account has no maximum allowed parental rating set but does have block content with tags set to "XXXXX". I remove it and they’re visible again. Any Ideas or pointers please? Tone
Solution Luke 42185 Posted August 29, 2015 Solution Posted August 29, 2015 Make sure that tag isn't assigned to a containing folder 1
Green_Trousers 0 Posted August 29, 2015 Author Posted August 29, 2015 Luke, Super fast response and good solution to my silly error. Thank you
