Audio Bitstreaming Mode set to HDMI Problems
Matt Salcedo
Emby Theater Version 3.0.5686.19243
 Audio Bitstreaming Mode set to HDMI is not working at all for any movie (all mkvs) and sometimes it works whenever it feels like it, wierd. The error message "There was an error processing the request" comes up. When I change the bitstreaming mode back to default it seems to be working perfectly fine every time I try to play a movie, not sure what the problem is.
Deathsquirrel
Install mpchc on that system.  Can it bitstream using LAV for the same files?  I have this issue with some audio formats.  Nothing to do with emby in my case.
Matt Salcedo
I have VLC. This problem was not happening before I re-installed Emby Theatre a couple of days ago.
