EPG using Fios QAM?
I'm very new so sorry in advance if I sound like an idiot!!
I'm using an AIW card to pull TV using FIOS local (no box, direct cable into PC card).  For the most part everything works. I can pull up an epg through nextPVR or emby and stuff populates (most....17 out of 20 channels will but I think I know why the last three will not... will test later).   Is there a way to add more complex data to the EPG like synopsis or episode data?  NOw, EPG populates show title only, example will be 1730 PBS: NOVA. Is there a way to pull in episode guide?Is this even possible? Is there a way to at least add program data to recorded show? Example, I recorded a NOVA show from PBS, show recorded fine, but shows up as NOVA with a NOVA icon, but there is no other data associated.
Thanks in advance.
Edited by paulgs3
I fixed it.
Doesn't work very well with the newest beta so I uninstalled and went back to stable.  I added schedule direct to nextpvr and everything is beautiful!!!
So... beta bad..... stable good.
Awesome job on this btw, just want to say thanks!!
