fraenhawk 61 Posted August 27, 2015 Posted August 27, 2015 This is occurring under 3.0.5713.4 with both Chrome and IE. I noticed that if the Short Overview is filled in, the label for it and even the short overview text itself is pushed inside the overview above. This can be seen in the screenshot as a barely visible grey text and a jumble of white in the last line of the full overview. Also, is it intentional that when a field is null, the label moves inside that field's space? It just looks odd since the lines don't collapse more so there is a larger space between lines that are empty. You can see this with the Tagline label being on the line and the larger gap between website and tagline than all other fields.
nopso66 0 Posted May 21, 2016 Posted May 21, 2016 This seems to be partly a function of the "Overview" field not automatically expanding/growing with its content. I'm noticing this across all browsers. Here's a screenshot from my own Metadata Manager:
Happy2Play 9800 Posted May 21, 2016 Posted May 21, 2016 Only happens in Metadata Manager. The edit pop-up window is fine. Tested on 5983.
