Wob76 22 Posted August 27, 2015 Posted August 27, 2015 Just wondering if it is possible to have the microphone button trigger the in app search, rather than the main menu\global search? I am sure one of my other apps maps the search in app, but it might be a google app and hence have more permission. It would be nice to be able to trigger a search with the button rather than having to navigate up to the search icon on screen. Thanks, Wob
ebr 16336 Posted August 27, 2015 Posted August 27, 2015 No. Just like on your phone - that button is hard-wired to the global Google search.
Wob76 22 Posted August 31, 2015 Author Posted August 31, 2015 Thanks ebr, I thought that might have been the case, but I was sure I had another app that grabbed control of it, must have been a google app or something. Wob
ebr 16336 Posted September 1, 2015 Posted September 1, 2015 If you find a non-Google app that does it let me know and I'll try to investigate. 1
Wob76 22 Posted September 1, 2015 Author Posted September 1, 2015 Thanks, I re-investigate and report back.
Wob76 22 Posted September 4, 2015 Author Posted September 4, 2015 I completed forgot to reply to this, distracted with out issues I found the app I was thinking of, I don't have many on my Nexus Player, anyway it is Netflix, when you press the mic button in the Netflix App it brings up the Netflix Search rather than the Global Search. Interesting thing is the Netflix Search doesn't even support the microphone. Thanks, Wob
ebr 16336 Posted September 4, 2015 Posted September 4, 2015 The docs specifically say that that button press is not delivered to applications but I've tried something for the next release. We'll have to see if it works. 1
Wob76 22 Posted September 5, 2015 Author Posted September 5, 2015 That is interesting, I look forward to trying it out.
ebr 16336 Posted September 5, 2015 Posted September 5, 2015 What can we do to test this? Hit the hard microphone button on your NP remote when in an Emby screen. It should now take you to our search (and listening for voice) instead of the global one. 1
ebr 16336 Posted September 5, 2015 Posted September 5, 2015 Will it make it to the FTV? Not unless Fire OS 5 supports it. Right now, the Fire gives no access to the search feature to apps. They want you searching Amazon.
CBers 7554 Posted September 5, 2015 Posted September 5, 2015 OK, thanks. I'll try on my NP tomorrow. Not had time today, but thought I'd try FTV while I thought about it
Wob76 22 Posted September 6, 2015 Author Posted September 6, 2015 Fantastic news ebr, nice work! Do we need to side load a version from somewhere for this? The version in the store is 1.0.80g from the 18th August. Thanks, Wob
ebr 16336 Posted September 6, 2015 Posted September 6, 2015 Fantastic news ebr, nice work! Do we need to side load a version from somewhere for this? The version in the store is 1.0.80g from the 18th August. Thanks, Wob Android Open Beta Testing
CBers 7554 Posted September 6, 2015 Posted September 6, 2015 Hit the hard microphone button on your NP remote when in an Emby screen. It should now take you to our search (and listening for voice) instead of the global one.OK, it works just fine, but if I do a 2nd search with the results still showing from the 1st search, then the Google search kicks in. I have to back out to the main Emby menu and start again.
ebr 16336 Posted September 6, 2015 Posted September 6, 2015 You mean you hit the hard mic button again...?
above1 45 Posted September 7, 2015 Posted September 7, 2015 You mean you hit the hard mic button again...? It does work great.. and yes.. hitting it twice kicks you to google search. 1
MrWebsmith 598 Posted September 7, 2015 Posted September 7, 2015 working well here.. like it.. thanks ebr!
CBers 7554 Posted September 7, 2015 Posted September 7, 2015 working well here.. like it.. thanks ebr! Does Google search kick in if you try a second search?
ebr 16336 Posted September 7, 2015 Posted September 7, 2015 Does Google search kick in if you try a second search? Yes that's going to happen in the current release. The next beta may fix it. 1
MrWebsmith 598 Posted September 7, 2015 Posted September 7, 2015 it does but i have to admit i only even tried that cause you reported it, cb.. if you back out of the results you can then perform a 2nd search ive noticed. 1
