e123enitan 276 Posted August 26, 2015 Posted August 26, 2015 At the emby plugin I turned on the Incremental sync to observer performance of the Kodi, as it behaves funny for the first few min, there I discovered that I does Increase sync each time that I powered up Kodi. But what is surprising is that it circle around same files each, the number of sync is the same each time the Kodi restart, what I could understand is take Friends S4 E22: The One With The Worst Best Man Ever it plays fine on Kodi, also when I review the file structure compared to other seasons there is no diff. I gone through the cycle of pulling logs several times, yet no change" Note, this movies and TV shows are not recently added to server. I am not sure where the issue lies either with the server or Kodi, I have researched t the extent of my limited knowledge, appreciate if you could review and let me know what to do next. Thanks for your support. Two logs at diff times http://xbmclogs.com/pmytv8zmh http://xbmclogs.com/pjbdytnkz
xnappo 1611 Posted August 26, 2015 Posted August 26, 2015 (edited) Do you have nfo/xml for this show? Series/Season/Episode xml/nfo? The last time we saw this it was due to a corrupt nfo file. These are not required, so if you have them, completely remove them (to a backup location) and see if the problem goes away after a server re-scan. If you want to figure out what is wrong with the NFO, you need to look at the server log after a re-scan and look for those items. Edited August 26, 2015 by xnappo
e123enitan 276 Posted August 26, 2015 Author Posted August 26, 2015 Do you have nfo/xml for this show? Series/Season/Episode xml/nfo? The last time we saw this it was due to a corrupt nfo file. These are not required, so if you have them, completely remove them (to a backup location) and see if the problem goes away after a server re-scan. If you want to figure out what is wrong with the NFO, you need to look at the server log after a re-scan and look for those items. Thanks I will check the nfo as you said
e123enitan 276 Posted August 27, 2015 Author Posted August 27, 2015 Thanks I will check the nfo as you said Something is weared, I can't placed it In my first log http://xbmclogs.com/pmytv8zmh in row 187 - 219 these I believed did not update Kodi coz of missing nfo or xml, but when I checked the server metadata/and individual movies folder all the info are stored inthere. Today I pulled a new loghttp://xbmclogs.com/pukor7ti1, I noticed diff set of movies where reported as missing nfo or xml. those reported yesterday are gone. Also I review metadata for TVshows for instance Friends S4, it have metadata identical to S3, I am not sure where identical data are stored and one of the season is reported in log as having issue, very confusing. Would it help if I post server log.? Thanks for looking into this issue.
e123enitan 276 Posted September 1, 2015 Author Posted September 1, 2015 Something is weared, I can't placed it In my first log http://xbmclogs.com/pmytv8zmh in row 187 - 219 these I believed did not update Kodi coz of missing nfo or xml, but when I checked the server metadata/and individual movies folder all the info are stored inthere. Today I pulled a new loghttp://xbmclogs.com/pukor7ti1, I noticed diff set of movies where reported as missing nfo or xml. those reported yesterday are gone. Also I review metadata for TVshows for instance Friends S4, it have metadata identical to S3, I am not sure where identical data are stored and one of the season is reported in log as having issue, very confusing. Would it help if I post server log.? Thanks for looking into this issue. latest log http://xbmclogs.com/phc0rindh After rebuilding my server and Kodi several times hoping this issue will disappeared, yet it persist. excused my limited knowledge, as per the log the it shows write to Kodi library, yet each time I reboot Kodi it repeats same process over and over, wondering how many times it will write to same library. It would help if the nature of error is indicated, at lease one could trouble shoot there onward, then this not reported as an error, except my lack of knowledge of ready log is an issue here. Could some one point me to where the issue can be corrected, as I am pulling hairs , I try to update log file but it seems it exceeds the max. KINDLY HELP Thanks
xnappo 1611 Posted September 1, 2015 Posted September 1, 2015 We need to look at the server log - can you post that? It is likely the server detecting these as changes and telling Emby - so we need to see why the server thinks they changed.
e123enitan 276 Posted September 2, 2015 Author Posted September 2, 2015 (edited) I am struggling to upload the server log, I have tried several times, i think, it is due to the volume of data created by server whiles in sync with kodi, anyone have idea how to upload large file.Thanks Edited September 2, 2015 by e123enitan
fc7 123 Posted September 2, 2015 Posted September 2, 2015 (edited) Zip it. It's text and I doubt that after compression it will be too big. BTW I suspect I have a similar problem but it's not happening to me every day. Some days when I turn on Kodi it's doing a "Sync Delete" for +6k. Today only 2 or 3. It's really weird since my library barely change and I don't have nfo or xml files in my library paths. The next time I see this I will share Kodi and Emby logs. Should I configure the addon login in info logging in advance to catch the problem? Right now it's set to none. Sent from my iPad using Tapatalk Edited September 2, 2015 by fc7 1
e123enitan 276 Posted September 2, 2015 Author Posted September 2, 2015 Zip it. It's text and I doubt that after compression it will be too big. BTW I suspect I have a similar problem but it's not happening to me every day. Some days when I turn on Kodi it's doing a "Sync Delete" for +6k. Today only 2 or 3. It's really weird since my library barely change and I don't have nfo or xml files in my library paths. The next time I see this I will share Kodi and Emby logs. Should I configure the addon login in info logging in advance to catch the problem? Right now it's set to none. Sent from my iPad using Tapatalk I zip the file yet it fails to upload, aside from that, surely I am not alone in this wired scenario, once I have the log I might reveled the cause of the issue. As you have said, for me some files have both nfo and xml or some one of the two not in any particular order and some files have non, I am not sure why this inconsistency happen. Also I have looked through my server to determine the where the nfo/or xml are saved , I couldn't find it. but one thing that is certain is both the server and Kodi do displays nfo fine and its information is consistent between the two system for movies and tvshow/season/episodes. anyway thanks for your input please share your log when you're chanced
fc7 123 Posted September 2, 2015 Posted September 2, 2015 Noup. These are all my plugins: Sent from my iPad using Tapatalk
e123enitan 276 Posted September 3, 2015 Author Posted September 3, 2015 @@fc7 do you have any server plugins that use external sources like Trakt? Someone else mentioned that it looked like Trackt was trying to update as well. NO
e123enitan 276 Posted September 3, 2015 Author Posted September 3, 2015 I have managed to post server logs in Dropbox Link to Kodi/Emby - as indicated in the logs the issue still persist http://xbmclogs.com/pgtgjy72w http://xbmclogs.com/ptdaazsds Server diff logs, not sure which of this is relevant https://www.dropbox.com/s/1dnnbvbsno66cdn/server-63576922259.txt?dl=0 https://www.dropbox.com/s/6b9hovyotvgu0bt/server-63576921600.txt?dl=0 https://www.dropbox.com/s/to66uwchc3uxy1p/server-63576919517.txt?dl=0 https://www.dropbox.com/s/c7zkf411lorf40i/server-63576919039.txt?dl=0 Thanks for looking into the issue, pls let me know what to do next.
e123enitan 276 Posted September 3, 2015 Author Posted September 3, 2015 (edited) Just scratching my head, I just compared the log in the first thread to the resent one-today, it appears that the earlier one have gone, replace with new list. Certainly, something wired is happening between server parsing data to/from Kodi Edited September 3, 2015 by e123enitan
e123enitan 276 Posted September 4, 2015 Author Posted September 4, 2015 yeah it looks like your items are being updated all the time, we are seeing this with other users as well, we are still looking into it. Nice, felt relief I thought I am going kuku, as I did not see anyone else raising this issue, well so nice to heard that the issue is being troubleshoot, let me know if you require further test and log reports on both server/Kodi. Cheers!
Angelblue05 4132 Posted September 4, 2015 Posted September 4, 2015 Oh so you started seeing the issue @? Maybe we need to talk to Luke at this point. See what changed in recent build that could cause this behavior. Then we'll get to the bottom of this wayyy faster. Sent from my iPhone using Tapatalk
