Angelblue05 4132 Posted October 1, 2015 Posted October 1, 2015 (edited) @@Palan @@cw-kid Hopefully I got this right, please test with 1.1.44 and let me know if everything works with stack://. Thanks! Edited October 2, 2015 by Angelblue05
Palan 2 Posted October 4, 2015 Author Posted October 4, 2015 @@Palan @@cw-kid Hopefully I got this right, please test with 1.1.44 and let me know if everything works with stack://. Thanks! Hi. Thanks for the update. I tried playing around with the new version. I couldn't get it to play dvd's without enabling 'Use local paths instead of addon redirect for playback'. And I was unfortunately still not able to get it to play disc 2. After looking in to it the only suggestion for how it could be done was adding the stack during database synchronization rather than during playback. But I don't know if that is feasible.
Angelblue05 4132 Posted October 4, 2015 Posted October 4, 2015 (edited) Hm... That's quite disappointing to hear. I had no issues with my test, but they were not dvds. They were labelled -cd1 -cd2 and they stacked into one playable file in Kodi - I could see it with the total time being for both items combined. @@Palan Can you provide your Kodi log? Thanks. Edited October 4, 2015 by Angelblue05
cw-kid 192 Posted October 4, 2015 Posted October 4, 2015 (edited) @@Palan @@cw-kid Hopefully I got this right, please test with 1.1.44 and let me know if everything works with stack://. Thanks! I just updated the add-on to v1.1.44 If I look at the God Father Part II title (which has two DVD discs) in the movie library, it says its 121 minutes. On TheMovieDB site it says the run time is 175 minutes. If I try to play The Godfather Part II it says opening stream and then nothing happens it doesn't play. If I then try to play The Godfather (Part 1) instead that plays OK. I don't have a lot of time today as my car needs fixing so will have to look at this later. EDIT: I am using the default plug-in paths btw. Edited October 4, 2015 by cw-kid
Angelblue05 4132 Posted October 4, 2015 Posted October 4, 2015 Ok, please provide a log when you can. Thank you guys. Hopefully, we can figure this out.
cw-kid 192 Posted October 4, 2015 Posted October 4, 2015 Hi Here is an INFO log for that session http://xbmclogs.com/p8qsvbr7j 1
Angelblue05 4132 Posted October 4, 2015 Posted October 4, 2015 (edited) Seems Kodi is not able to access your share with current credentials. Not sure what's that's about. I will look into adding credentials to passwords.xml rather than to the path. Maybe that will make a difference? : 12:36:21 T:5756 WARNING: XFILE::CWin32SMBDirectory::ConnectAndAuthenticate: Can't connect to "\\WHS\Movies" with username "xbmc" and with password because of conflict of credential. Will try to close current connections. Hopefully, the player is simply having difficulties with credentials being part of the path, because later when you tried the first part, the credentials are represented differently. Edited October 4, 2015 by Angelblue05
cw-kid 192 Posted October 4, 2015 Posted October 4, 2015 (edited) I'm not sure what that means? About the credentials, as I said the movie title next to it played OK (single disc). Probably unrelated - only difference was my laptop was on Wifi and not connected to the LAN cable. I turned off Wifi and connected the LAN cable and tried again, same result the movie title that has two DVD discs does not start to play. It did use to play OK (the first disc) before the add-on updates. Here is another log for this session http://xbmclogs.com/pmeqntn2j Edited October 4, 2015 by cw-kid
Angelblue05 4132 Posted October 4, 2015 Posted October 4, 2015 (edited) What it means is that the player is unable to load your files due to credentials issue. If you check your logs, you will see that when its part of the stack items, the path is different than when playing the single item in terms of credentials. So I'm hoping the issue is not the stack itself, but simply having credentials being part of the path, when using stack items. Anyway, I'll look into it more later today hopefully. Sent from my iPhone using Tapatalk Edited October 4, 2015 by Angelblue05
cw-kid 192 Posted October 4, 2015 Posted October 4, 2015 OK many thanks. So I don't need to do anything at my end about credentials in Kodi?
Angelblue05 4132 Posted October 4, 2015 Posted October 4, 2015 Well you could try without credentials in the add-on settings, see if that makes a difference? Sent from my iPhone using Tapatalk
cw-kid 192 Posted October 4, 2015 Posted October 4, 2015 Same thing says Opening Stream and then nothing. I removed the username and password from the Emby add-on saved and then restarted Kodi. I can still play the other movie title however with the single disc. I thought I needed the credentials added in the add-on settings for SMB playback? Or only when using Direct Paths? and not plug-in paths. Here is the log for this session http://xbmclogs.com/pkzoehuvu 1
Angelblue05 4132 Posted October 4, 2015 Posted October 4, 2015 Well it depends, for credentials. Not exactly sure when Kodi requires them. On certain setup, people need them to get their files playing, however if you are able to play files without it, then there's no need to add them to the add-on settings. Well at least the credential error is gone. However it doesn't even attempt at playing the file now... I will have to check it out later. If you are able to enable Kodi debug and try playback and post that log, it would be great! Thanks for the assistance in helping troubleshoot this. Sent from my iPhone using Tapatalk
cw-kid 192 Posted October 4, 2015 Posted October 4, 2015 Must be because I am on a Windows PC that also has network access via my logged in user account. On the OpenElec HTPCs they will need the credentials in the add-on settings etc. Here is the DEBUG log http://xbmclogs.com/pumxaa19g
Palan 2 Posted October 4, 2015 Author Posted October 4, 2015 Here is a log file. I first played a single disc movie, which played fine. Then started a 2 disc movie which never started. kodi.log
Angelblue05 4132 Posted October 4, 2015 Posted October 4, 2015 @@cw-kid I didn't mean add-on debug, but Kodi debug. Sent from my iPhone using Tapatalk
Angelblue05 4132 Posted October 4, 2015 Posted October 4, 2015 Here is a log file. I first played a single disc movie, which played fine. Then started a 2 disc movie which never started. According to your log, you are on version 1.1.39. Can you update to 1.1.44? Then try starting playback again, and post that log? Let me know of the title, and also are you using plugin paths, because that's what I'm looking to make work. Thank Sent from my iPhone using Tapatalk
Palan 2 Posted October 5, 2015 Author Posted October 5, 2015 According to your log, you are on version 1.1.39. Can you update to 1.1.44? Then try starting playback again, and post that log? Let me know of the title, and also are you using plugin paths, because that's what I'm looking to make work. Thank The add-on information in Kodi says I'm using 1.1.44. Is it possible that it didn't update completely? This was with the settings reset to default.
cw-kid 192 Posted October 5, 2015 Posted October 5, 2015 @@cw-kid I didn't mean add-on debug, but Kodi debug. Sent from my iPhone using Tapatalk Sorry here is a Kodi DEBUG one with add-on set to INFO http://xbmclogs.com/psi4lstu0
Angelblue05 4132 Posted October 11, 2015 Posted October 11, 2015 (edited) @@Palan Can you give this build a try? I've been working really hard resolving some issues... Please let me know if it works, if it doesn't, post your Kodi log. Thank you. Edited October 15, 2015 by Angelblue05
Palan 2 Posted October 15, 2015 Author Posted October 15, 2015 @@Palan Can you give this build a try? I've been working really hard resolving some issues... Please let me know if it works, if it doesn't, post your Kodi log. Thank you. Thanks for working on this. I finally had time to test it. With this version it is possible to skip to disc 2 so it seems to Work :-) The only downside is that it is not possible to switch chapters on the discs, even if there is only one disc. 1
Angelblue05 4132 Posted October 15, 2015 Posted October 15, 2015 When you say the chapters, do you mean the dvd chapters that you select from the dvd menu? Sent from my iPhone using Tapatalk
Angelblue05 4132 Posted October 15, 2015 Posted October 15, 2015 @@Palan You should be able to access them via the dvd menu osd button (where the mouse cursor is). I have just tested it:
Palan 2 Posted October 16, 2015 Author Posted October 16, 2015 @@Palan You should be able to access them via the dvd menu osd button (where the mouse cursor is). I have just tested it: You are correct, that works. But you are no longer able to click the >| and |< buttons to do it. It is a small thing and it is possible to get around it. Good job. 1
Angelblue05 4132 Posted October 16, 2015 Posted October 16, 2015 I'll check it out when I have a moment thanks for the feedback! Sent from my iPhone using Tapatalk
