hifiaudio2 48 Posted August 25, 2015 Posted August 25, 2015 Version 3.0.5713.1 (just noticed there is a new version but havent tested that) If I pull up the web client on the machine running the server, and go to "movies", it incorrectly now shows both "parents movies" and also "kids movies", which are in a separate folder and library. If I pull up this same web view from another PC or Emby Connect, it only shows the movies it should and does not include "kids movies" in the main movie view.
sh0rty 730 Posted August 25, 2015 Posted August 25, 2015 Version 3.0.5713.1 (just noticed there is a new version but havent tested that) If I pull up the web client on the machine running the server, and go to "movies", it incorrectly now shows both "parents movies" and also "kids movies", which are in a separate folder and library. If I pull up this same web view from another PC or Emby Connect, it only shows the movies it should and does not include "kids movies" in the main movie view. Perhaps automated grouping of the two movie sections is activated in Home Screen settings?
jellowe 8 Posted August 25, 2015 Posted August 25, 2015 Same problem I'm having. It worked until the latest update. Clients display everything the way they should, but the web client on the server ignores several library settings.
hifiaudio2 48 Posted August 25, 2015 Author Posted August 25, 2015 Perhaps automated grouping of the two movie sections is activated in Home Screen settings? I can check, but like the last person to respond said, this has worked for a long time and I have not changed anything.
hifiaudio2 48 Posted August 25, 2015 Author Posted August 25, 2015 Well, whatever happened in the 13.2 update seems to have fixed the issue.
