yardameus 221 Posted November 27, 2013 Posted November 27, 2013 I recently switched up my media info icons, and I can't remember what I did to get them to be refreshed in MBC before (or MB2). Does anyone know what to do to get them to show? Library.db deletion? Some cache I need to delete? It's been a week or so since I switched them and they still haven't switched over.
ebr 16337 Posted November 27, 2013 Posted November 27, 2013 I'm not sure. Since these come from the server now, we may have no way of knowing they changed. 1
ebr 16337 Posted November 27, 2013 Posted November 27, 2013 Delete just the "custom" folder underneath the mbc imagecache folder. 1
yardameus 221 Posted November 27, 2013 Author Posted November 27, 2013 (edited) Gotcha, thanks for the help. edit: There was actually nothing in the custom folder. It was there, I deleted it, it came back but nothing changed. I'll just clear out the whole folder, spruce things up anyways. User error. I somehow managed to miss out on putting the correct subfolder (all, theme) within MediaInfo, just never caught it cause the themes I was using used by default what I had in the MediaInfo folder. Thanks for the help. Edited November 28, 2013 by yardameus
