Xzener 729 Posted August 28, 2015 Posted August 28, 2015 (edited) Beta here too. Hadn't changed a thing, just noticed it was broke when I was trying to help out. Funny thing is, it still sends commands. Edited August 28, 2015 by Xzener 1
chef 3811 Posted August 28, 2015 Posted August 28, 2015 It is the UI which is broken. All the information gathered in the .net code is good to go, it is only when the HTML/jquery code tries to access the XML that everything goes sideways. But without a good configuration page, the XML can't be written to. What in the world is goin on? 1
chef 3811 Posted August 28, 2015 Posted August 28, 2015 (edited) blah... Edited August 29, 2015 by chef 1
Solution chef 3811 Posted August 29, 2015 Solution Posted August 29, 2015 (edited) I have finally recreated this! @@tp546. I now experience the same thing as you! I'm going back to the Stable Release and I'll see if it changes anything! @@Xzener too EDIT: moving back to the last stable release fixes the plugin, something is up with the Beta. Edited August 29, 2015 by chef 1
chef 3811 Posted August 29, 2015 Posted August 29, 2015 Server beta, or Vera beta?? Server beta. Moving back to official release of the server fixes things. 1
tp546 41 Posted August 29, 2015 Author Posted August 29, 2015 I have finally recreated this! @@tp546. I now experience the same thing as you! I'm going back to the Stable Release and I'll see if it changes anything! @@Xzener too EDIT: moving back to the last stable release fixes the plugin, something is up with the Beta. awesome! last stable server release? 1
tp546 41 Posted August 29, 2015 Author Posted August 29, 2015 Server beta. Moving back to official release of the server fixes things. sorry but how do i do that? do i need to uninstall and then reinstall or is there an easier way? i already changed my settings to release instead of beta. 1
Happy2Play 9814 Posted August 29, 2015 Posted August 29, 2015 You just need to reinstall from the website. 1
chef 3811 Posted August 29, 2015 Posted August 29, 2015 (edited) Yes from the "download" section of the emby website, http://emby.media/download/ Choose Windows, then Stable Release Edited August 29, 2015 by chef 1
tp546 41 Posted August 29, 2015 Author Posted August 29, 2015 @@chef you rock! It is working for me now! At least it is pulling up my Vera info, I assume the functionality still works just fine without having tested it yet. The only question I have is do you know what the problem is with the current beta? i just want to make sure that whatever it is will be fixed before it makes it to public release. thanks! 1
chef 3811 Posted August 29, 2015 Posted August 29, 2015 (edited) Here is what I do know: 1. Updating to beta server breaks Plugin UI 2. Plugin Libraraies from GitHub are broken, it has something to do with the .net framework of the Dynaimic Link Libraries. Probably when they add the live TV abilities. 3. The library "Mediabrowse.Model.dll" in particular is broken when attempting to load through NuGet. I am going to go back and replace all the threading in the plugin! Right now it loads like a granny out getting her ovaltine. It can be way faster with threading restored. I also added the ILogger Interface to the plugin which will log everything single thing the plugin is doing from start. This will at least allow us to check all the ins and outs of how Vera is behaving, and we will be able to know in the future if it is us or the server on the fritz! I also perfected scheduling for events in the new release, now you can ignore events which would trigger scenes during certain times of the day. Stay tuned for an update. If anything we can't get outa this, it's thath E plugin needed an overhaul anyway. Note: we better tell Luke about what happened here. Something is wrong with the server Beta. He has been busy with Live TV, he might not know about the issue. Edited August 29, 2015 by chef 1
Xzener 729 Posted August 30, 2015 Posted August 30, 2015 (edited) Chef, hate to say it but the plugin is a mess. Refreshing the app (browser) lists EVERY single item on my network. It no longer lists device/client. I have no idea how to configure a specific device/client because it lists multiple. The only device I was able to configure correctly is "THEATERXBOX". I thought the app was setup to where it would only see running clients... Why are ALL my network attached devices listed?? When I refreshed, none of these devices are running Emby clients. Edited August 30, 2015 by Xzener 1
chef 3811 Posted August 30, 2015 Posted August 30, 2015 (edited) @@Xzener that should be fix in 1.0.0.1285 If a device is on and you restart the server: You will need to restart the client program after a server restart in order for them to show up. They now get removed from the list once they are turned off. If they are saved, they will always be available. Did I explain that okay? Sorry about that, this issue is reminance of prior listing issues. Edited August 30, 2015 by chef 1
Xzener 729 Posted August 30, 2015 Posted August 30, 2015 @@chef That fixed it, well done. I am now able to differentiate which client/device is which and configure it. No more overwhelming list of connected network items. Thanks! 1
tp546 41 Posted August 30, 2015 Author Posted August 30, 2015 @@chef - this is awesome. thanks so much for all your hard work on this. my friends are very impressed by this when they come over. 1
chef 3811 Posted August 31, 2015 Posted August 31, 2015 Great, now I am having trouble. When I "Add" a new device from the list the configuration doesn't transfer the device ID over to the scene editing page.
chef 3811 Posted September 1, 2015 Posted September 1, 2015 (edited) New version fixes ID problems. Edited September 1, 2015 by chef
Xzener 729 Posted September 4, 2015 Posted September 4, 2015 @@chef The server in is a restart infinite loop with the new upgrade.
chef 3811 Posted September 4, 2015 Posted September 4, 2015 @@Xzener Weird, I fixed it. It had something to do with Version Numbers. I upped the Major Version number to One, and it fixed the issue. 1
Xzener 729 Posted September 4, 2015 Posted September 4, 2015 No need for an update, but the "Save" text on the button is not centered. Just FYI.
