BC101 31 Posted December 28, 2013 Posted December 28, 2013 (edited) Thanks Tikuf, works ATV> GET /mediabrowser/Videos/9aa15e8dcc7b90989a977dfa068d9f6d/stream.m3u8?audioCodec=Aac&VideoCodec=h264&VideoBitRate=3000000&AudioBitRate=128000&audiochannels=2&maxwidth=1280 HTTP/1.1 Host: 192.168.1.125:8096 Range: bytes=0-1 X-Playback-Session-Id: 431C3EC0-072A-4081-B291-71742313E603 Accept-Encoding: identity Accept: */* Accept-Language: en-us Connection: keep-alive User-Agent: AppleCoreMedia/1.0.0.11B554a (Apple TV; U; CPU OS 7_0_4 like Mac OS X; en_us) Edited December 28, 2013 by BC101
BC101 31 Posted December 28, 2013 Posted December 28, 2013 Will have to take packet dumps as its failing for some reason after about 1min
Tikuf 663 Posted December 28, 2013 Posted December 28, 2013 Show me the server and ffmpeg logs will see if there is anything there that hints.
BC101 31 Posted December 28, 2013 Posted December 28, 2013 The original video ID I used ended up starting near the end, and never actually got to the end it instead prematurely ended. So to troubleshoot, I just changed video ID to another video and the weird thing is it doesn't start at 0:00 it starts in the middle of the intro, so 30seconds in? See the video I just created: http://www.youtube.com/watch?v=1GEipDdfBgc
BC101 31 Posted December 28, 2013 Posted December 28, 2013 If my mkv's are Ac3 5.1 channel, what options are best to ensure they come out as 5.1 channel on the ATV, do you know? I tried changing from Aac to ac3 but it broke, I tried changing from 2 to 6 under audiochannels but that didnt work.
Tikuf 663 Posted December 28, 2013 Posted December 28, 2013 Ya 5.1 of transcode is not implemented yet. As a stop gap you can play with http://server-ip:8096/mediabrowser/Videos/502e652c886521c5d2bda00dffd6371c/stream.m3u8?audioCodec=copy&VideoCodec=h264&VideoBitRate=3000000&maxwidth=1280 to keep orig audio (not sure how it will segment with ac3 but it should be ok) http://server-ip:8096/mediabrowser/Videos/502e652c886521c5d2bda00dffd6371c/stream?static=true to stream the orig file
BC101 31 Posted December 28, 2013 Posted December 28, 2013 (edited) I see the Apple TV is capable of outputting 5.1 Dolby Digital as I can confirm from the NetFlix app (I can query from my receiver to see what the ATV is pushing). With your suggestion: http://192.168.1.125:8096/mediabrowser/Videos/9e34e0f28bcda58406baee1e761b5636/stream.m3u8?audioCodec=copy&VideoCodec=h264&VideoBitRate=3000000&maxwidth=1280 \\edit: oops i was trying a DTS source , I've switched to a AC3 source movie and can confirm 5.1 is working fine with the syntax ?audioCodec=copy -- Thanks Obviously stream?static=true fails because the source is mkv. Edited December 28, 2013 by BC101
BC101 31 Posted December 28, 2013 Posted December 28, 2013 So what options needs to be used to reencode DTS to AC3 5.1 channels?
Tikuf 663 Posted December 28, 2013 Posted December 28, 2013 So what options needs to be used to reencode DTS to AC3 5.1 channels? Right now nothing we will add it but our attention is elsewhere right now. I will chat to Luke about adding ac3 5.1 and aac 5.1 (ac3 can be utilized by roku as well)
Luke 42198 Posted December 28, 2013 Posted December 28, 2013 we will add it, not to worry. i love what you've done so far, but i personally would suggest focusing on browsing the library first. once this becomes a real project, we'll be glad to allocate more developer time to help you. there's a lot of people out there who know python, so a little recruiting on github could probably get you some help.
BC101 31 Posted December 28, 2013 Posted December 28, 2013 Yup, getting support is a goal, I can hack an interface together but all data elements get pulled from Plex at the moment. However I hardcoded the stream to pull from MB3 so I know it works (given my source is AC3 5.1 I can even get the thing to play with surround sound), fast-forward works, etc. 1
Tikuf 663 Posted December 28, 2013 Posted December 28, 2013 Obviously stream?static=true fails because the source is mkv. if you need to re-contain the original source I would suggest using ts as the container (if all the internal codecs are supported) you can call it with http://server-ip:8096/mediabrowser/Videos/502e652c886521c5d2bda00dffd6371c/stream.ts?audioCodec=copy&VideoCodec=copy
Tikuf 663 Posted December 28, 2013 Posted December 28, 2013 Hls is not a requirement unless he is connecting via cell network. But yes he could use either hls or ts http://server-ip:8096/mediabrowser/Videos/502e652c886521c5d2bda00dffd6371c/stream.m3u8?audioCodec=copy&VideoCodec=copy or http://server-ip:8096/mediabrowser/Videos/502e652c886521c5d2bda00dffd6371c/stream.ts?audioCodec=copy&VideoCodec=copy ts will (atm) have a faster start up time (very small diff when re containing). So yes it would probably be best to use hls but as it is a re-contain the segment times will likely not be in compliance with apple spec anyhow.
BC101 31 Posted December 28, 2013 Posted December 28, 2013 (edited) The .ts failed stream.ts?audioCodec=copy&VideoCodec=copy ATV> GET /mediabrowser/Videos/363f2e2c17dbc86ee4b83220f638c0c5/stream.ts?audioCodec=copy&VideoCodec=copy HTTP/1.1 Host: 192.168.1.125:8096 Range: bytes=0-1 X-Playback-Session-Id: 58D5EF2D-2579-43D5-914A-A4DBAFE924E1 Accept-Encoding: identity Accept: */* Accept-Language: en-us Connection: keep-alive User-Agent: AppleCoreMedia/1.0.0.11B554a (Apple TV; U; CPU OS 7_0_4 like Mac OS X; en_us) MB3> HTTP/1.1 200 OK Transfer-Encoding: chunked Content-Type: video/mp2t Accept-Ranges: none Server: Microsoft-HTTPAPI/2.0 X-UA-Compatible: IE=Edge X-Powered-By: ServiceStack/4.001 Win32NT/.NET Access-Control-Allow-Origin: * Access-Control-Allow-Methods: GET, POST, PUT, DELETE, OPTIONS Access-Control-Allow-Headers: Content-Type Date: Sat, 28 Dec 2013 22:26:14 GMT The ATV failed to handle that video type I guess. Trying .m3u8 now Edited December 28, 2013 by BC101
BC101 31 Posted December 28, 2013 Posted December 28, 2013 Weird, webserver didnt respond to this request from ATV: ATV> GET /mediabrowser/Videos/363f2e2c17dbc86ee4b83220f638c0c5/stream.m3u8?audioCodec=copy&VideoCodec=copy HTTP/1.1 Host: 192.168.1.125:8096 X-Playback-Session-Id: B6CFAE0D-8D2B-4F3F-BE4E-780D19ECCF4A Accept-Encoding: gzip Accept: */* Accept-Language: en-us Connection: keep-alive User-Agent: AppleCoreMedia/1.0.0.11B554a (Apple TV; U; CPU OS 7_0_4 like Mac OS X; en_us)
BC101 31 Posted December 28, 2013 Posted December 28, 2013 (edited) Ooops, could it be because the movie is AVI? Don't know how i missed that, thought it was mkv. I found one movie that's mkv with AC3 audio and will test that now. webserver logs: 2013-12-28 14:33:27.9557, Debug, HttpServer, HTTP GET request received on worker 0 from 192.168.1.34:49347 Url: http://192.168.1.125:8096/mediabrowser/Videos/363f2e2c17dbc86ee4b83220f638c0c5/stream.m3u8?audioCodec=copy&VideoCodec=copy Headers: X-Playback-Session-Id=198E2892-DCE7-415B-BCC6-536FA6F4C424,Connection=keep-alive,Accept=*/*,Accept-Encoding=gzip,Accept-Language=en-us,Host=192.168.1.125:8096,User-Agent=AppleCoreMedia/1.0.0.11B554a (Apple TV; U; CPU OS 7_0_4 like Mac OS X; en_us) 2013-12-28 14:33:27.9607, Info, App, C:\Users\xxxxx\AppData\Roaming\MediaBrowser-Server\ffmpeg\ffmpeg20131209\ffmpeg.exe -i file:"Q:\VIDs\Movies\SOMEMOVIE\SOMEMOVIE CD1 of 2.avi" -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -sc_threshold 0 -codec:a:0 copy -hls_time 10 -start_number 0 -hls_list_size 1440 "C:\Users\xxxxxxx\AppData\Roaming\MediaBrowser-Server\cache\encoded-media\b2a62178-7349-8025-f127-3768ccbf02b8.m3u8" 2013-12-28 14:33:28.0847, Info, App, FFMpeg exited with code 1 for C:\Users\xxxxxx\AppData\Roaming\MediaBrowser-Server\cache\encoded-media\b2a62178-7349-8025-f127-3768ccbf02b8.m3u8 2013-12-28 14:34:48.0222, Debug, HttpServer, HTTP GET request received on worker 1 from 127.0.0.1:28709 Url: http://localhost:8096/mediabrowser/dashboard/advanced.html Edited December 28, 2013 by BC101
BC101 31 Posted December 28, 2013 Posted December 28, 2013 found a mkv with AC3 audio movie, and it works with .m3u8 but not .ts
BC101 31 Posted December 28, 2013 Posted December 28, 2013 Webserver logs: 2013-12-28 14:44:32.6787, Debug, HttpServer, HTTP GET request received on worker 0 from 192.168.1.34:49384 Url: http://192.168.1.125:8096/mediabrowser/Videos/49004eb2a14536dec47bdb6610f4c00d/stream.ts?audioCodec=copy&VideoCodec=copy Headers: X-Playback-Session-Id=9A55F254-0673-49FB-9489-46EB1019EB3A,Connection=keep-alive,Accept=*/*,Accept-Encoding=identity,Accept-Language=en-us,Host=192.168.1.125:8096,Range=bytes=0-1,User-Agent=AppleCoreMedia/1.0.0.11B554a (Apple TV; U; CPU OS 7_0_4 like Mac OS X; en_us) 2013-12-28 14:44:32.6837, Info, App, C:\Users\xxxxxxxx\AppData\Roaming\MediaBrowser-Server\ffmpeg\ffmpeg20131209\ffmpeg.exe -i file:"Q:\VIDs\Movies\Old School (2003) [1080p.BluRay.x264-HANGOVER]\Old School (2003) [1080p.BluRay.x264-HANGOVER].mkv" -map 0:0 -map 0:1 -map -0:s -vcodec copy -bsf h264_mp4toannexb -threads 0 -acodec copy "C:\Users\xxxxxxxx\AppData\Roaming\MediaBrowser-Server\cache\encoded-media\20b15a52-b506-63d7-fff8-68dcf638e5ea.ts" 2013-12-28 14:44:34.8198, Error, App, Error streaming media The specified network name is no longer available System.Net.HttpListenerException at System.Net.HttpResponseStream.EndWrite(IAsyncResult asyncResult) at System.IO.Stream.<BeginEndWriteAsync>b__17(Stream stream, IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncTrimPromise`1.Complete(TInstance thisRef, Func`3 endMethod, IAsyncResult asyncResult, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.IO.Stream.<CopyToAsyncInternal>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Api.Playback.Progressive.ProgressiveStreamWriter.<StreamFile>d__3.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Api.Playback.Progressive.ProgressiveStreamWriter.<WriteToAsync>d__0.MoveNext() 2013-12-28 14:44:34.8198, Error, HttpResponseExtensionsInternal, Error occured while Processing Request: [AggregateException] One or more errors occurred. One or more errors occurred. System.AggregateException at System.Threading.Tasks.Task.WaitAll(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) at MediaBrowser.Api.Playback.Progressive.ProgressiveStreamWriter.WriteTo(Stream responseStream) at ServiceStack.HttpResponseExtensionsInternal.WriteToOutputStream(IResponse response, Object result, Byte[] bodyPrefix, Byte[] bodySuffix) at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse(IResponse response, Object result, ResponseSerializerDelegate defaultAction, IRequest request, Byte[] bodyPrefix, Byte[] bodySuffix) InnerException: System.Net.HttpListenerException The specified network name is no longer available at System.Net.HttpResponseStream.EndWrite(IAsyncResult asyncResult) at System.IO.Stream.<BeginEndWriteAsync>b__17(Stream stream, IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncTrimPromise`1.Complete(TInstance thisRef, Func`3 endMethod, IAsyncResult asyncResult, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.IO.Stream.<CopyToAsyncInternal>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Api.Playback.Progressive.ProgressiveStreamWriter.<StreamFile>d__3.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Api.Playback.Progressive.ProgressiveStreamWriter.<WriteToAsync>d__0.MoveNext() 2013-12-28 14:44:34.8198, Debug, HttpServer, Response code 500 sent to 192.168.1.34:49384. Response time: 2148.1228 ms Url: http://192.168.1.125:8096/mediabrowser/Videos/49004eb2a14536dec47bdb6610f4c00d/stream.ts?audioCodec=copy&VideoCodec=copy Headers: X-UA-Compatible=IE=Edge,X-Powered-By=ServiceStack/4.001 Win32NT/.NET,Access-Control-Allow-Origin=*,Access-Control-Allow-Methods=GET, POST, PUT, DELETE, OPTIONS,Access-Control-Allow-Headers=Content-Type,Accept-Ranges=none,Content-Type=video/mp2t,Transfer-Encoding=chunked 2013-12-28 14:44:35.8319, Info, App, Killing ffmpeg process for C:\Users\xxxxxxxx\AppData\Roaming\MediaBrowser-Server\cache\encoded-media\20b15a52-b506-63d7-fff8-68dcf638e5ea.ts 2013-12-28 14:44:35.8319, Info, App, FFMpeg exited with code -1 for C:\Users\xxxxxxxx\AppData\Roaming\MediaBrowser-Server\cache\encoded-media\20b15a52-b506-63d7-fff8-68dcf638e5ea.ts 2013-12-28 14:44:35.8319, Info, App, Deleting partial stream file(s) C:\Users\xxxxxxxx\AppData\Roaming\MediaBrowser-Server\cache\encoded-media\20b15a52-b506-63d7-fff8-68dcf638e5ea.ts FFMpeg logs: ffmpeg version N-58882-ga12f679 Copyright © 2000-2013 the FFmpeg developers built on Dec 8 2013 22:01:45 with gcc 4.8.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib libavutil 52. 56.100 / 52. 56.100 libavcodec 55. 45.100 / 55. 45.100 libavformat 55. 22.100 / 55. 22.100 libavdevice 55. 5.102 / 55. 5.102 libavfilter 3. 92.100 / 3. 92.100 libswscale 2. 5.101 / 2. 5.101 libswresample 0. 17.104 / 0. 17.104 libpostproc 52. 3.100 / 52. 3.100 Input #0, matroska,webm, from 'file:Q:\VIDs\Movies\Old School (2003) [1080p.BluRay.x264-HANGOVER]\Old School (2003) [1080p.BluRay.x264-HANGOVER].mkv': Metadata: creation_time : 2008-12-10 14:30:00 Duration: 01:31:50.53, start: 0.000000, bitrate: 12387 kb/s Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x816, SAR 1:1 DAR 40:17, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default) Output #0, mpegts, to 'C:\Users\xxxxxxxr\AppData\Roaming\MediaBrowser-Server\cache\encoded-media\20b15a52-b506-63d7-fff8-68dcf638e5ea.ts': Metadata: encoder : Lavf55.22.100 Stream #0:0(eng): Video: h264, yuv420p, 1920x816 [sAR 1:1 DAR 40:17], q=2-31, 23.98 fps, 90k tbn, 23.98 tbc (default) Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), 640 kb/s (default) Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help frame= 982 fps=0.0 q=-1.0 size= 64503kB time=00:00:40.92 bitrate=12910.7kbits/s frame= 1957 fps=1957 q=-1.0 size= 120866kB time=00:01:21.69 bitrate=12119.7kbits/s frame= 2802 fps=1868 q=-1.0 size= 177063kB time=00:01:57.02 bitrate=12394.9kbits/s frame= 3526 fps=1763 q=-1.0 size= 233136kB time=00:02:27.07 bitrate=12985.8kbits/s frame= 4407 fps=1763 q=-1.0 size= 289193kB time=00:03:03.96 bitrate=12877.6kbits/s frame= 5274 fps=1757 q=-1.0 size= 345713kB time=00:03:40.00 bitrate=12873.1kbits/s
Tikuf 663 Posted December 28, 2013 Posted December 28, 2013 Ah ok do you have a video spec list for apple tv they must not support ts without an m3u8 (kinda strange but apple is apple )
BC101 31 Posted December 28, 2013 Posted December 28, 2013 Unfortunately best I have is http://support.apple.com/kb/sp648 and http://en.wikipedia.org/wiki/Apple_TV .
Tikuf 663 Posted December 28, 2013 Posted December 28, 2013 Ok I will hunt around see what i can find but streaming to is only a small part of the puzzle we can work on the logic of when to transcode etc later but for now I would suggest working on the library display as luke suggested as it is likely to take more time than streaming (from the looks).
BC101 31 Posted December 28, 2013 Posted December 28, 2013 Here's a demo showing 5.1 surround pass-thru is working -- 4
BC101 31 Posted December 28, 2013 Posted December 28, 2013 (edited) Starting here: https://github.com/iBaa/PlexConnect/blob/master/XMLConverter.py What converts {{VAL(title)}} in Library.xml ( https://github.com/iBaa/PlexConnect/blob/master/assets/templates/Library.xml#L35 ) from its "placeholder/template element" type to the actual data that's pulled from Plex? This is something I'm struggling with as yesterday was my first introduction to basic python. I don't know how to setup a debug/development environment in which I can trace such things. Edited December 28, 2013 by BC101
