JeremyG 30 Posted September 22, 2015 Posted September 22, 2015 Not sure why, in my case, I'm having to do this additional step, but at least it seems to finally allow me to restore my people data. From the little spot checking I have been doing, it doesn't appear that I have lost my Watched status trackers. My wife would kill me if I had, so that's a good thing, especially when I go to apply this trick to my TV Show media folder! Thanks for this post. I'm having the same problem. No matter what I did, the people wouldn't populate properly. (this is after a reload of my whole WMC/emby computer) Your method worked on one of my movies doing it individually. However next I'm going to try to just blow away all XML/NFO files from one of my libraries and see if that fixes it.
JeremyG 30 Posted September 23, 2015 Posted September 23, 2015 Thanks for this post. I'm having the same problem. No matter what I did, the people wouldn't populate properly. (this is after a reload of my whole WMC/emby computer) Your method worked on one of my movies doing it individually. However next I'm going to try to just blow away all XML/NFO files from one of my libraries and see if that fixes it. I still have no way of refreshing all people. Even using the method that pclausen used, I still get only a handful of people
Happy2Play 9814 Posted September 23, 2015 Posted September 23, 2015 Are you getting a lot of 429 errors in your log? Error means to many requests from TMDB.
JeremyG 30 Posted September 23, 2015 Posted September 23, 2015 (edited) No, in fact I can download just fine manually. But for instance the TV show "Arrested Development". It lists 9 actors but only has pictures of Portia De Rossi ....then I downloaded Jeffrey Tambor myself using Metadata Manager. Before my system reload I just has pics of all actors for every show/movie. Edited September 23, 2015 by JeremyG
JeremyG 30 Posted September 24, 2015 Posted September 24, 2015 This is very frustrating. Is there any way to just blow away all "people" in the database and start over?
Happy2Play 9814 Posted September 24, 2015 Posted September 24, 2015 This is very frustrating. Is there any way to just blow away all "people" in the database and start over? The only way I can see would be deleting your library.db. %appdata%\Emby-Server\data
JeremyG 30 Posted September 24, 2015 Posted September 24, 2015 Thanks for this! My people went from 1800 to 3500+. They still aren't all there but the logs look like maybe the image server flagged me "Access Token Invalid or Expired". I'll update people again tomorrow and see if it complete.
JeremyG 30 Posted September 25, 2015 Posted September 25, 2015 No luck Initially got a large batch of people, more than I did before, but now it's stuck.
pclausen 44 Posted September 25, 2015 Posted September 25, 2015 (edited) My understanding is that this is a known bug and that it will be addressed in a future release. I currently have 43,495 people for (2.306) movies and 6,917 for TV (154 shows, 8,640 Episodes), for a total of 50,412 People (probably a little less due to some Movie people also being in TV Shows). I have People configured to only pick up Actors and Directors and I would say I have maybe 10% images at this time. When I add new Movies and TV Episodes, any new People are added correctly with images. When I look in my Emby-Server/metadata/people folder, I have a total of 5,823 subfolders, subtracting 30 (the 1,5,A-Z and one Russian letter folder), I have a net of 5,793 actual People folders, which is close to the 10% of People that have images (5,793/50,412*100 = 11.49% to be exact). Apparently, the way it works is that Emby only creates folders for People once there is metadata/images to store for them, presumably after picking it up from imdb. So the bug appears that, for existing titles, when running either the people scan or the refresh from the root media folder under Metadata Manager, Emby does not go out to imdb to pick up metadata for existing people that do not yet have any. Edited September 25, 2015 by pclausen
pclausen 44 Posted September 26, 2015 Posted September 26, 2015 Installed the latest dev release (3.0.5747.18286) and still no nice. 2015-09-26 11:40:04.1508 Info - App: Executing Refresh people 2015-09-26 11:40:36.2190 Info - App: People validation complete 2015-09-26 11:40:36.3283 Info - App: Refresh people Completed after 0 minute(s) and 32 seconds 2015-09-26 11:40:36.3283 Info - ServerManager: Sending web socket message ScheduledTaskEnded 2015-09-26 11:40:36.4533 Error - HttpServer: Error in HttpListenerResponseWrapper: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. *** Error Report *** Version: 3.0.5747.18286 Command line: C:\Users\peter\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\peter\AppData\Roaming\Emby-Server Application Path: C:\Users\peter\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. System.IO.IOException at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at SocketHttpListener.Net.ResponseStream.InternalWrite(Byte[] buffer, Int32 offset, Int32 count) at SocketHttpListener.Net.ResponseStream.Close() at MediaBrowser.Server.Implementations.HttpServer.SocketSharp.Extensions.CloseOutputStream(HttpListenerResponse response, ILogger logger) InnerException: System.Net.Sockets.SocketException An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size)
