Ernst 29 Posted November 27, 2013 Posted November 27, 2013 Hi, MBIntros seem to have stopped working. I tried with both MBT (latest version 3.0.5078) and MBC (also latest version (3.0.96) Does the plugin need updating? I originally posted this in the MBT section, but I guess it is more general then that.
slaman 1 Posted November 27, 2013 Posted November 27, 2013 (edited) I installed MB Intros for the first time yesterday, and it didn't work. I thought I had missed a setting or something, but I guess it's because of an issue with the latest update? I tried with Version 3.0.5076.20161 and 3.0.5078.42671 Edited August 20, 2014 by slaman
slaman 1 Posted November 27, 2013 Posted November 27, 2013 (edited) This is the only thing that appears in the log when I press play using MBT... 2013-11-27 00:09:44.5400, Info, App, C:\Users\xxxxx\AppData\Roaming\MediaBrowser-Server\ffmpeg\ffmpeg20131110\ffmpeg.exe -i file:"\\NAS-3\Volume_1\Movies\Aladdin (1992)\Aladdin.1992.720p.HDTV.x264-hV.mkv" -map 0:0 -map 0:1 -map -0:s -vcodec libvpx -force_key_frames expr:if(isnan(prev_forced_t),gte(t,.1),gte(t,prev_forced_t+5)) -vf "scale=min(iw\,1280):-1" -speed 16 -quality good -profile:v 0 -slices 8 -b:v 420000 -vsync vfr -threads 2 -acodec libvorbis -ac 2 -ab 128000 -af "aresample=async=1000,volume=2.000000" "C:\Users\XXXX\AppData\Roaming\MediaBrowser-Server\cache\encoded-media\b90d322b-4e4e-830c-598e-4ec4dbf7c009.webm" 2013-11-27 00:09:45.2034, Error, SessionWebSocketListener, Unable to find session based on web socket message No trailer... and MBC is the same. Edited August 20, 2014 by slaman
Ernst 29 Posted November 27, 2013 Author Posted November 27, 2013 Ok, I made a new log file with debug enabled: https://www.dropbox.com/s/ib9ekb5mvtovwwm/server-63521145808.log and the MBT log: https://www.dropbox.com/s/rylixs1i3uc7uib/theater-63521145928.log Hope this will shed some light.
ebr 16342 Posted November 27, 2013 Posted November 27, 2013 Looks like a server release broke it. @@Luke can you please put the public method back?
Ernst 29 Posted November 27, 2013 Author Posted November 27, 2013 Thanks chief bottle washer, will be looking out for a new server release then
Ernst 29 Posted November 28, 2013 Author Posted November 28, 2013 No problem, we'll just have to be patient. Thanks for letting us know though.
ebr 16342 Posted November 28, 2013 Posted November 28, 2013 Well guys, it looks like an internal server change has broken this and I won't be able to fix it until I'm back in town this weekend. Sorry.
Solution ebr 16342 Posted November 28, 2013 Solution Posted November 28, 2013 Snuck away from the table and just put up a version that hopefully fixes this. I couldn't test much though cuz my Mom came after me with a rolling pin because I had the computer out . Someone please give it a try. Happy Thanksgiving yanks. 2
ebr 16342 Posted November 29, 2013 Posted November 29, 2013 Thx. Those are all mbt issues. Sent from my SCH-I545 using Tapatalk
Ernst 29 Posted November 29, 2013 Author Posted November 29, 2013 Thanks Ebr, I gave it a spin and I can confirm that the intro's now play. There are some cosmetic issues, but I can't figure out whether that is the plugin or MBT. To give you an idea: Sound of intro plays but video starts a little later, cutting of the start of the intro (initially black screen). When the main movie starts, the title of the movie is not refreshed (still showing the name of the intro) and also the timeline isn't updated (showing the length of the intro not the main movie). I guess this is MBT, but I can be wrong. Anyway, I will marke the issue solved. Thanks man. Make sure you come back from the family in one peace
tboneynot 2 Posted November 30, 2013 Posted November 30, 2013 Hmmm.. Still not working for me. Is there a link for how to set this plugin up? I thought I'd followed all the instructions, but perhaps I've missed something.
Luke 42252 Posted November 30, 2013 Posted November 30, 2013 The issues are likely all MBT-related. It's alpha software so don't go burning yourself out trying to fix something you have no control over. I will get to it when I can.
