kjp4756 41 Posted August 23, 2015 Posted August 23, 2015 Emby Version 3.0.5675.1 Freenas 9.3 emby in standard jail installed from ports I noticed my upcoming episodes tab wasn't showing my tv shows properly. Shows were missing, nothing listed for August, etc... I thought doing an advanced refresh of my tv shows would fix this. I noticed in the metadata manager the path for my tv shows section looked a little off. Is this a bug? Here is a screen shot.
Happy2Play 9811 Posted August 23, 2015 Posted August 23, 2015 That is the correct path. Did you navigate to that location? There is a link in that folder to your library path.
kjp4756 41 Posted August 23, 2015 Author Posted August 23, 2015 There is no such path on my system. The path should be '\var\db\mediabrowser\root\default' For some reason the path substituion is inserting a \\freenas after the \var\db. This doesn't seem to affect anything. I just thought it looked rather weird. If I go in to an actual show in my TV library the path is correctly showing as '\\freenas\media\TV\show.....'
