above1 45 Posted August 22, 2015 Posted August 22, 2015 (edited) So I just bought a Nexus Player TV puck. I'm going to install Andriod M on it as the Live TV function with the HDHR-CC seem now to be all there. Mpeg2 hardware decoding now is enabled on it. We'll even get a full guide now, fast channel changing as no need to transcode and whatnot. Will Emby work properly with Andriod M? I would assume so but would like to know. This will replace my Roku3. Eventually I will also get a Shield TV once I update my samsung in the media room to a 4K tv. Waiting on that to have HD audio.. which seems it's right around the corner. Thanks! LB Edited August 22, 2015 by above1
ebr 16336 Posted August 22, 2015 Posted August 22, 2015 I have not tested it yet but don't anticipate any problems. 1
above1 45 Posted August 22, 2015 Author Posted August 22, 2015 I have not tested it yet but don't anticipate any problems. Sweet.. Better than saying it doesn't work.. thx!
Latchmor 584 Posted August 23, 2015 Posted August 23, 2015 My Nexus player is on M and the limited Emby testing I did was fine.
above1 45 Posted August 23, 2015 Author Posted August 23, 2015 My Nexus player is on M and the limited Emby testing I did was fine. Awesome.. Can't wait to get my and replace the Roku3. I'll send the Roku downstairs..
