Iorifly 15 Posted August 20, 2015 Posted August 20, 2015 I did a reset on BD and is no longer seeking the movies. I tried again on hand to delete the bank, and the same thing. Generates the file but it does not search the movies in Emby. my log: http://pastebin.com/CgqrimHj
Angelblue05 4132 Posted August 21, 2015 Posted August 21, 2015 (edited) Disable the incremental sync plugin option in the add-on settings then it should work. I'm not sure why it's doing that, looking into it, but couldn't find anything that explains the behavior. Then you can reenable the option afterwards. Edited August 21, 2015 by Angelblue05 1
Iorifly 15 Posted August 21, 2015 Author Posted August 21, 2015 First thank you! You're becoming my guardian angel. Friend, I still decided to blank my movie list.
Angelblue05 4132 Posted August 21, 2015 Posted August 21, 2015 Ok to make sure I understand what you are talking about. You've tried to reset your library, and when Kodi restarts, it doesn't sync your library back up? 1
Iorifly 15 Posted August 21, 2015 Author Posted August 21, 2015 That. I tried to reset, restarted and movies do not come back. MyVideos93 deleted the file, restart the kodi and nothing. After desmarquei what I asked and nothing.
Angelblue05 4132 Posted August 21, 2015 Posted August 21, 2015 And you are positive the incremental sync plugin is disabled in the add-on settings > sync options? 1
Angelblue05 4132 Posted August 21, 2015 Posted August 21, 2015 Ok can you post another log of you starting Kodi? This time disable Kodi debug please, it's not needed. Just set our add-on debug to Info. Thanks!
Iorifly 15 Posted August 21, 2015 Author Posted August 21, 2015 @angelsblue05, Everything working! I think it was a matter of waiting. I can activate the function again? Thanks again!Thanks again!Thanks again!Thanks again!Thanks again! 1
Angelblue05 4132 Posted August 21, 2015 Posted August 21, 2015 Yes you can reactive the function again. 1
