tp546 41 Posted August 20, 2015 Posted August 20, 2015 this may be a little far fetched, but i am hoping that on one specific PC running Emby for WMC, I can get it to integrate with my home automation (Vera/Z-wave) using http commands (I already know how to do this part). Basically, what I am hoping to do is that for specific media types (HD DVD, Blu Ray, DVD), I can include an http command as part of the intro that would then adjust the lighting. Would this be possible at all?
Solution ddecaro 4 Posted August 20, 2015 Solution Posted August 20, 2015 Have you checked out the Vera Home Automation Plugin available in the catalog? I have not started home automation but it might be what your looking for. http://emby.media/community/index.php?/topic/19685-vera-home-automation-plugin-emby-vera/?hl=vera 1
tp546 41 Posted August 20, 2015 Author Posted August 20, 2015 Thanks! I didn't even realize there was such a thing.
tp546 41 Posted August 20, 2015 Author Posted August 20, 2015 @@tp546 Do you get your HA all sorted out?? yeah, it only took a minute once i found out there was a plugin. i love it 1
