Parental Controls Not Sending Notifications
@@xnappo @@Angelblue05 or @ One other question... If the user didn't have the item before and after an update now has access and you receive it as an update item instead of an add item will it still get added into the Kodi library?
Angelblue05
It should be ok if you send items to remove that's not in the Kodi library. It does a verification in the database first. Item added and updated is the same method, so it should not cause any problem. It adds the item if it's not found, or updates it if it's found in the Kodi database.
  • Like 1
Just ran a few tests...
When a user's parental control access is changed there is no notification at all... So my previous statement is not necessarily true... I should be able to do what I proposed above if an item is changed... But I think I will still need to do a scheduled task to capture when a person's parental control access is changed... And allow it to be run manually for those (like me) who don't like to wait...
Guest
