lja 51 Posted August 18, 2015 Posted August 18, 2015 I have a backdrop set up in Emby Server. Should this appear in Emby for WMC? How can I set up a backdrop to appear on the home screen? EHS. is not enabled.
ebr 16333 Posted August 19, 2015 Posted August 19, 2015 If you are using the server view functionality, I don't think there is any way to do that anymore. If using Legacy Browsing mode, then the backdrop in your root/default folder should be used, I believe.
