Never_More 19 Posted August 16, 2015 Posted August 16, 2015 (edited) Good day to all - Here is the situation I have - and I cant seem find a post with the same question or situation I have - If there is please direct me to it and save alot of typing on your part... ;-) I did a rebuild of my server and baught a new HDD to replace the 2 2tb drives I had all my collections on. I copied the collections (Movies,Cartoon and Music) to the new drive - Some of the Art work became unreadable and does not show - Sooo here is the situation I want to do a complete refresh of all my art and NFO's (I do not mind waiting) - Is this correct way of doing the new refresh - I go to the server meta settings and click on the movie heading (latter the cartoons and Music) and click refresh or do I need to go the movie's 1 by 1 and click refresh - Also I want the old stuff deleted so the server does not get confused what to display Like I said before if there is a post with this info please link it and ill go from there - Thank you for all the help Never_More. Edited August 16, 2015 by Never_More
Solution Happy2Play 9800 Posted August 17, 2015 Solution Posted August 17, 2015 Not positive if a refresh will replace the current images, but the there is an option in Advance Refresh to replace images. Metadata Manager-Folder level (Movies)-click the three dots-Advance Refresh-Use the drop downs for metadata (Refresh all data) and images (Replace existing images) 1
Never_More 19 Posted August 17, 2015 Author Posted August 17, 2015 TY worked like a charm ... Took a look at the explorer folders, to make sure it was doing what is should, and all pics and nfo were being replaced.. - TY for the help and advice ...
