Vicpa 612 Posted August 18, 2015 Posted August 18, 2015 No, Sorry for the confusion. I meant the Microsoft win 10 Movies and TV app
FrostByte 5453 Posted August 18, 2015 Posted August 18, 2015 I don't see on my computer and I never loaded it unless it came default in the upgrade
Vicpa 612 Posted August 18, 2015 Posted August 18, 2015 (edited) Just cause you can (free) download it from the windows store Microsoft Movies and TV in the states "Film and TV in the UK. not sure where you are Edited August 18, 2015 by Vicpa
FrostByte 5453 Posted August 18, 2015 Posted August 18, 2015 Nope, I don't see that as a installed app
FrostByte 5453 Posted August 18, 2015 Posted August 18, 2015 I did have Shark codecs installed, but I uninstalled and still have the same issue
7illusions 1249 Posted August 18, 2015 Author Posted August 18, 2015 Ah, can you check this. http://emby.media/community/index.php?/topic/4502-how-to-fix-cant-play-videos-on-app-or-modern-ie/ 1
FrostByte 5453 Posted August 18, 2015 Posted August 18, 2015 Oh, my. The Shark install program did disable a MS decoder if I remember right now (though it did give you the option to not do that if you wanted). I'll try the fix on the link and get back. That is the same thing I'm seeing though '
FrostByte 5453 Posted August 18, 2015 Posted August 18, 2015 Well...noooooooooooooooow I feel dumb. Shark did disable those in the red box and after enabling them using that utility all is good. Thanks
FrostByte 5453 Posted August 18, 2015 Posted August 18, 2015 That's probably the same problem a couple of those others are having in the release section
Vicpa 612 Posted August 19, 2015 Posted August 19, 2015 (edited) Hi @FrostByte Happy you and 7 got it sorted. How do your mkv's look? You rip at a much higher quality setting. I am thinking we need a play all from here option in music, maybe albums and play lists. I am liking the multi select (is that new or did I just figure it out) Edited August 19, 2015 by Vicpa
FrostByte 5453 Posted August 19, 2015 Posted August 19, 2015 (edited) I like the Play From Here button, but would like to see more control over it I guess. I clicked play from here on season 3 of GoT and it added not only the rest of season 3, but all the episodes from season 4 and 5 also to Now Playing. I guess it couldn't read my mind that I only want the rest of season 3 Edited August 19, 2015 by FrostByte
FrostByte 5453 Posted August 19, 2015 Posted August 19, 2015 (edited) Hi @FrostByte Happy you and 7 got it sorted. How do your mkv's look? You rip at a much higher quality setting. I am thinking we need a play all from here option in music, maybe albums and play lists. I am liking the multi select (is that new or did I just figure it out) The lossless mkvs are probably not real noticeable over the crf 16/17 mkvs I used to do, but I wanted to be ready for when I win the lottery and got an 80" tv to replace my 55" one Didn't want to redo my movies every couple years which is what I seemed to be doing before. It's a lot faster though because there is no encoding being done, just ripping Edited August 19, 2015 by FrostByte
FrostByte 5453 Posted August 19, 2015 Posted August 19, 2015 (edited) Does it normally take awhile for the ffmpeg process to stop if you stop a movie? I usually go into the processes and kill it because I think it's still transcoding after I stop the video. Not sure if the app could kill the process when clicking "stop" because it takes up a lot of cpu. I think I had several running at once when I was playing around starting/stopping movies. Edited August 19, 2015 by FrostByte
Vicpa 612 Posted August 19, 2015 Posted August 19, 2015 Hi 7 My number one bug/feature request The track name sometimes overlays the time counter on the music screensaver. I don't know if it is a scaling thing or what. I have reported it before either a big deal or really low on the list. Believe it or not the screensaver is a huge crowd pleaser. I get the ooos and ahhs when friends are over and music is playing. Think you can "refactor" that away. Thanks -vicpa
7illusions 1249 Posted August 20, 2015 Author Posted August 20, 2015 Hi 7 My number one bug/feature request The track name sometimes overlays the time counter on the music screensaver. I don't know if it is a scaling thing or what. I have reported it before either a big deal or really low on the list. Believe it or not the screensaver is a huge crowd pleaser. I get the ooos and ahhs when friends are over and music is playing. Think you can "refactor" that away. Thanks -vicpa I can even do better. But you will have to wait another 24h for next build. 2
7illusions 1249 Posted August 21, 2015 Author Posted August 21, 2015 New build is up. Hope you like it. (Screensaver starts after 5 sec. This will be another value once it's not build in Debug mode) 1
FrostByte 5453 Posted August 21, 2015 Posted August 21, 2015 Movies with PCM audio are being transcoded. A lot of older movies on BD are released with PCM. The settings file seems to have no effect on them being transcoded. Here the first chapter of a movie as an example http://1drv.ms/1WJid2e I like the new transparent drop down 1
Vicpa 612 Posted August 21, 2015 Posted August 21, 2015 Hi 7 I think you out did yourself this time Awesome Thanks -Vicpa 1
FrostByte 5453 Posted August 21, 2015 Posted August 21, 2015 (edited) The app crashes every time I go to Music and then click Artists. The loading circle spins and then the app closes. Fatal app log http://pastebin.com/aNHyNLjG Log http://pastebin.com/h7qgRhqz Edited August 21, 2015 by FrostByte
FrostByte 5453 Posted August 21, 2015 Posted August 21, 2015 The screen saver when playing music is cool 1
FrostByte 5453 Posted August 21, 2015 Posted August 21, 2015 (edited) Ignore post #42. I got PCM to play direct Added two parameters to this line (bold). I think "pcm" can be deleted as that isn't the correct codec name <DirectPlayProfile container="mkv" audioCodec="aac,ac3,eac3,mp3,mp2,pcm,pcm_s16le,pcm_s24le" videoCodec="h264,hevc" type="Video" /> Also had to increase this line, I think the default was only 10000000 and I don't have very many mkv files below 10 Mbps <MaxStreamingBitrate>30000000</MaxStreamingBitrate> Edited August 21, 2015 by FrostByte 1
Vicpa 612 Posted August 21, 2015 Posted August 21, 2015 Hi, For what ever reason I don't have a problem When I click Artists. flac seems to working fine.
FrostByte 5453 Posted August 21, 2015 Posted August 21, 2015 (edited) I got it to work once. But the other 20 times I still get that error. I thought I had fixed it changing one of the parameters, but I'm getting that error again Edited August 21, 2015 by FrostByte
7illusions 1249 Posted August 21, 2015 Author Posted August 21, 2015 New build. Standard screensaver changed, feedback MUCH needed. Updated the streamingprofile PCM and the max streaming bitrate. Couldn't reproduce the Artist crash though. 1
7illusions 1249 Posted August 21, 2015 Author Posted August 21, 2015 New build. Missed the tagline for the screensaver. 1
