Olywa123 46 Posted August 15, 2015 Posted August 15, 2015 (edited) Hi there, A minor gripe I discovered recently when auto-organising some files that contain multiple episodes, Server Version 3.0.5675.1. Attached is an example (I've seen it happen previously with other files). Where a video file contain two or more episodes, when auto-renaming the files, the 'S' for season in the filename gets left off when writing to the destination (so S01E01-E02 becomes 01E01-E02). Without the prefix 'S' for season, this results in all files being recognised by the server as (and grabbing metadata only for) episode 01 of the season. You end up with what looks like lot of duplicate episode 1's. A minor annoyance that is easily resolved manually (adding back the missing S and refreshing) but I guess this is a simple code/formula fix. Many thanks, Olywa Edited August 15, 2015 by Olywa123
Solution Luke 42185 Posted August 15, 2015 Solution Posted August 15, 2015 It's probably your configured pattern because by default it doesn't write with s01e01-e01, but instead it uses 1x04-x05. 1
Olywa123 46 Posted August 15, 2015 Author Posted August 15, 2015 Wow - thanks for the fast response Luke - of course you were absolutely correct. Missed those setting when double checking
