Jasoon 9 Posted August 15, 2015 Posted August 15, 2015 Im thinking of getting a SSD for running windows 7 and emby off, would i see much of a speed increase and is it worth it? Im looking at getting a 120gb SSD possibly something like :- http://www.ebuyer.com/709697-sandisk-plus-120gb-sataiii-2-5inch-ssd-sdssda-120g-g25 All my movies will be on normal hard drives but i was thinking that if i have emby and emby theater on the SSD it might speed things up
ebr 16335 Posted August 15, 2015 Posted August 15, 2015 Using an SSD for your OS drive can be one of the most effective performance improvements you can make to your machine. So, yes.
Deathsquirrel 745 Posted August 15, 2015 Posted August 15, 2015 I saw a significant boost in emby's web page serving performance moving it and the os to a SSD.
FrostByte 5454 Posted August 15, 2015 Posted August 15, 2015 Would moving images/metadata to where Emby is installed with the OS on a SSD be faster also then? Right now mine are located with the media on my larger drives. I prefer them where they are at, but would consider moving them if it helped.
ebr 16335 Posted August 15, 2015 Posted August 15, 2015 Would moving images/metadata to where Emby is installed with the OS on a SSD be faster also then? Right now mine are located with the media on my larger drives. I prefer them where they are at, but would consider moving them if it helped. No. Those items are all cached at multiple levels already. 1
Jasoon 9 Posted August 16, 2015 Author Posted August 16, 2015 thanks for the advise guys, think im going to order one, was toying with going for the 240gb but i think for now ill go for the 120gb
ebr 16335 Posted August 16, 2015 Posted August 16, 2015 thanks for the advise guys, think im going to order one, was toying with going for the 240gb but i think for now ill go for the 120gb Get as big as you can make yourself afford. Space runs out quickly these days... 1
Jasoon 9 Posted August 17, 2015 Author Posted August 17, 2015 Ive went for the 120gb not because of cost but more because its all i need...i hope currently my C: drive is 450gb, 387gb is used but 128gb is music 11gb is pictures and 175gb is video leaving ~73gb which is the OS and programs
wolf359 6 Posted August 18, 2015 Posted August 18, 2015 Use cccleaner as well tbat will clear out loads of your unwanted files
Jasoon 9 Posted August 20, 2015 Author Posted August 20, 2015 Well i got my SSD installed and everything seems a lot faster It has also cured my issue of EMBY server crashing all the time..so its win win 1
